Do you think I can hit 300rwhp N/A?
Green&GoldGT
302
Virginia
This is my goal before the end of the summer. I'm not going to touch the heads. After I had my cams installed my numbers were 265/285 with a MAC CAI, flowmasters, O/R H, and the XCal 2 tune. I replaced the CAI with a JLT budget kit which makes it a "ram air" now since the MAC makes the A/F rich at 4000 rpm and above. I've also added Granatelli's new plenum. I'm going to get my Hooker longtubes and X-pipe installed, which will help alot.
Now after that I'm debating on getting some more mods to hit my goal. A 75mm TB, pulleys, Canton windage tray, COP connectors, a LMAF, and the JLT kit from the MAF to TB. I know I'll need a tune but which mods are worthless for my goal? Is 300 possible?
here are my buddies results with comp 262's
Hope this post contributes to what can be achieved with these cams...
First of the car is a 2001 w/ 80k Miles...
Full Mods: PA Racing K-Member, 90/10s, Moto Pullies, K&N FIPK, Accufab Plenum & 75 MM TB, Comp Cams 262, Hedman LT, UPR X, SLP PowerFlo CB, MGW Shifter, 373s, NittoDrag 315 on 17/10.5, Raptor Shift Light, Dyno Tuned by Edwin... @ Sanoli Performance...
Dyno Numbers: Prior to tune SCT tune: 284hp @ 5300 / 310tq @ 4150
after tune: 302hp @ 5550 / 317tq @ 4150
E.T.'s 12.7-12.9 all nite long!
most recent ET 12.6 on slicks and skinnies
windage tray is pointless(unless u are gonna build the engine),lmaf is no better than the stock maf,supercharged its a different story.
Longtubes will help but 300rwhp is a pretty hard to hit.Most usually miss it.
If trying to go fast at the track ,try to lighten up the car.Most peaple forget that the sn95's are pigs.
I read a MM&FF tech article online where they were modding a stock GT. I know their numbers are often elevated, but they added a C&L 80mm mass air meter and gained 8 hp. The car was stock with just a K&N filter and ud pulleys. Being that cams demand more air in, is it worth it to buy one. If yes, then what size considering they put a 80mm MAF in a stock car.
Stock is either a 80mm or 85mm depending on your year.
DOnt invest a lot of thought on mm&ff articles.Unless u go poweradder a maf is NOT needed.
