DO YOU THINK THIS IS AN "A" CODE
  • Thread starter Thread starter 12sec67
  • Start date Start date Sep 13, 2005
12sec67
1,301
San Diego, Ca
Sep 13, 2005
  • Sep 13, 2005
the carb looks like a 2 barrel, it has drum brakes, no power anything
or am i wrong
link to ebay:
http://cgi.ebay.com/ebaymotors/Ford...iewItemQQcategoryZ6236QQitemZ4574359589QQrdZ1
mfp4073
387
Hells Ditch, FL
Sep 13, 2005
  • Sep 13, 2005
My 67 came with a 289 A code from the factory, power steering, 4 wheel drum. Someone changed it over to a 2bbl intake at some point, but the engine was a 4bbl motor. There is nothing out of the ordinary to have a 4bbl car with no power and 4 wheel drum.
12sec67
1,301
San Diego, Ca
Sep 13, 2005
  • Sep 13, 2005
that sucks... thanks for messing with my fun!
degins
361
Texas
Sep 13, 2005
  • Sep 13, 2005
or am i wrong
link to ebay:
An A code without the 4 barrel intake and carb is essentially a C code. The 2 and 4 barrel heads are identical. I would also be suspect of any classic that is outwardly clean, but is a mess under the hood. This indicates a quick cosmetic restoration. I'd be willing to bet that the Bondo is 1/4" thick on the lower quarters.
mfp4073
387
Hells Ditch, FL
Sep 13, 2005
  • Sep 13, 2005
Actually they do list a vin...5F09A*****
C
chrua
  • Sep 13, 2005
im just curious cuz i suposofely(sp? its late) have an "A" code. Are they worth that much compared to a "C" code? I bought mine for $1850 and a guy at a mustang place said it would go for $3500. it had a crappy interior, brakes so bad i had to get new rotors, and the engine barely ran. $3500?
mfp4073
387
Hells Ditch, FL
Sep 13, 2005
  • Sep 13, 2005
dont worry about it. The difference in price is really not signficant. If it was a 6cyl and a conversion was done, then you would need to be worried about it.
CochinoFilipino
171
CA
Sep 14, 2005
  • Sep 14, 2005
chrua,
Right now the trend is to to modify so the value is not affected much today. But this trend could end or slowdown someday. Then your A-code with disc brakes could be worth significantly more than a C-code with disc conversion. Just a thought,
D
Doc Voodoo
257
Conn
Sep 14, 2005
  • Sep 14, 2005
I can not see the carb you are talking about but the Id number looks like its an A.
Its not a GT if thats what yea want to know .
302 coupe
1,952
Macon, Ga.
Sep 14, 2005
#10
  • Sep 14, 2005
  • #10
that car is covered in bondo.....
krash kendall
1,258
Aldergrove, B.C. Canada
Sep 14, 2005
#11
  • Sep 14, 2005
  • #11
The carb has the vacuum advance port in the same location as my old two barrel and the same choke assembly if that helps.
-The tail light panel is damaged as well as the deck lid.
-The valve covers were painted while on the engine - there's blue paint on everything from the wires to the exhaust - just trying to dress up a bagged motor
-The driver's side frame rail looks wrinkly and the strut rod brace looks cracked. The passenger strut rod brace was bent in. These things make appear to have had front driver's side collision at some time.
-I don't know why the fuel line goes from the fuel pump to inside the fender.
-The entire underside is undercoated including the shocks and springs.
All in all the car looks "Good from far, far from good."
LMan
1,246
Mom's basement
Sep 15, 2005
#12
  • Sep 15, 2005
  • #12
yep, looks like crumpled tinfoil that was straightened and painted. Lots of rust hiding in there, bet the cowl is shot.
Id pass.
302 coupe
1,952
Macon, Ga.
Sep 15, 2005
#13
  • Sep 15, 2005
  • #13
its bid to over 10,000 with 6 hours left. Someones gonna be really disappointed, and I don't mean the seller.
krash kendall
1,258
Sep 15, 2005
#14
  • Sep 15, 2005
  • #14
Check out the door alignment in this picture as well as the deck lid. Also, being an automatic one wouldn't think the "parking brake" behind the rear wheel would be neccessary.
Clicky for Picky
65fastback2+2
1,229
Louisville, KY
Sep 15, 2005
#15
  • Sep 15, 2005
  • #15
id be willing to bet thats not the original motor....A-code's did have a better compression ratio than C-code's....that ignition coil isnt located where they normally are...on top of the manifold....but i guess you can place that anywhere you want....the blue valve covers on a 65 car that is supposed to have gold valve covers makes me think the guy knows nothing about mustangs...
mfp4073
387
Hells Ditch, FL
Sep 15, 2005
#16
  • Sep 15, 2005
  • #16
Heck, look at the lower rear lip of the deck lid....yeah, that car is a basket case. The door alignment scares me. Quick note, the coil is where its supposed to be unless they did it differnt on 65-66s. Also, no lock in the drivers side door?
Edbert
3,548
32
109
Austin TX
Sep 15, 2005
#17
  • Sep 15, 2005
  • #17
The A/C engine is the same except for the manifold/carb, you are correct. But what makes that car an A-code versus a C-code is the VIN not the induction
I agree with your assesment on the appearance of the body/paint versus the engine too. Heavy undercoating sets off rust alarms for me.
Of course my car is getting the engine/drivetrain beautified but the body needs a lot of work.
mfp4073
387
Hells Ditch, FL
Sep 15, 2005
#18
  • Sep 15, 2005
  • #18
Wasnt there a difference in flat vs dish pistons too?
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
L
For Sale 1966 GT Fastback
  • lwg8tr0514
  • Apr 29, 2025
  • Classic Mustangs For Sale
Classic Mustangs For Sale Apr 29, 2025
lwg8tr0514
L
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
