damacman
Guys, re-read my original post on page 1. Powershifting is an art ! It is critical to do the following things simultaneously :
1. Shift as quickly as you can from one gear to the next -- this means you have to pull / push the shifter as hard and as fast as you can. This is why aftermarket shifters have adjustable stops!
2. Depress the clutch fully as you begin upshifting and release the clutch fully as you seat the shifter in the next gear. This is exactly what I described on the first page by "striking" the clutch and not riding it.
3. Do all of this within the RPM window that the synchronizers allow the smoothest transition at WOT -- for me, it's between 5500 and 6000.
btw . . . if you wanna' be classified as good, this entire process should take little more than a few tenths of a second. Any slower, and you'll continually have problems.
As for the Tri-Ax and other spring-loaded shifters (Pro 5.0), the EASIEST way to hit third is to unwrapp your fingers from the shifter (after your second gear pull) and push the handle DIRECTLY forward with your palm. It will go RIGHT in THIRD and not grind or protest one bit.
btw. . . unless you're the late Steve Collison, powershifting in flip flops is certainly not recommended . . . !
Yeah the thing is like i am a pretty aggressive driver but then when shifting my baby....yeah I have not powershifted yet, but its getting tempting...That is good info you posted about the "striking" of the clutch. the way you desribe sounds just as I imagine it should be
I have some stories
