Does anyone else have starter solenoid problems all the time?
Kdubslugga
1,515
Akron, OH
Ive serioulsy replaced my solenoid maybe 7 or 8 times in 7 years. It sticks on me all the time. I crank to start and the starter keeps on turning. I have to yank the battery cable to stop it.. I tap the solenoid with a hammer a problem goes away. I try and start it again, same problem. I go replace the solenoid and it works great for about a year or so but it always comes back. No clue why, ive tried Motorcraft ones, autozone ones etc, all of them do it!! No clue why it does this!
Starter Solenoid Problems
The fenderwell solenoid has always been a problem when carrying the amperage of the starter. The problem can be almost eliminated with the high torque starter. In that situation the fenderwell solenoid only carries the amperage of the starter relay.
No Crank checklist for 5.0 Mustangs
Revised 09-July-2009 to reorder stuck solenoid help.
No crank. slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of both no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a know problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstuck and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See Automotive Test Tools for help for help troubleshooting voltage drops across connections and components. .
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
attachment.php
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
mine would stick like that with a mini starter, i had to get a new starter. i woulkd check the solenoid wiring too, most of the wires go on one side, and i think there is only one wire on the other that goes to the starrrter itself.
"edit":just saw the other post
If the battery is discharged enough that the engine cranks a little slow, it can help the solenoid contacts stick.
I was facing the same problem for a long time that I almost sold my car out of frustration. I traced my problem with a test light to a faulty safety neutral switch which would sometimes work and when it wasn't it would hang my starter. I just bypassed the wiring and now I have had no hung starter. I used to think it was the solenoid because everytime I replaced it it would start with no problem but only for a short time. Good luck and hope you find your electrical gremlin.
I had this problem with my old car. Tore up no less than 4 starter solenoids before I found the heavy-duty one from NAPA (it's red). Then I never had another problem.
Basically what happens is either the wire from the solonoid to the starter is creating to much resistance or starter is drawing too many amps during starting, which in turn causes the solonoid contacts to stick. Try replacing the cable first with a good quality cable. Then the starter if that doesn't correct it.
Wow so upon further inspectin, the cable running from the solenoid to the starter is in bad shape! Where it rests on the k-member it has worn itself very thin and copper wiring is exposed and they green and about half gone!! I think i may have found the problem!! lol
It's not good. The cable obviously needs to be replaced. If you wanted to try and test it, you could insulate the bare spot and then do a drop-test while cranking. I would just replace the cable however.
