Does anyone see any reason why this wouldnt work?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Ok, this is something Ive been thinking about doing but finally might actually do it. I have a shift light on my a-pillar, but I want to take it off of there, and take the bulb out, then hook up an LED to it that I got from the parts store and put the shift light itself under the dash out of sight and drill a hole somewhere and put the LED coming out there. I was thinking on the clock face all the way to the drivers side of the clock. It should work right?
As stated above, I just hid mine in the A/C vent.
What you want to do is not hard at all. Just have to measure the output voltage that activates the light, and use resistors on the diode(LED) that you chose. I can't remember off the top of my head, but I think a 3V LED takes a 240ohm resistor on the positive side to make it accept 12v without smoking instantly.
Otherwise, you have a great idea which should cost less than 5 bucks if you already have the shiftlight.
Let us know how it turns out, I am interested.
Your typical cheapo LED's can't handle more than 1.5 volts usually, so make sure you do your math first and check it out with a multimeter before hooking them up. Other than that, it should work fine and be way cooler than those old fashion bulbs.
