i saw your clip on the stang nice horse any ways is it cold outside because i saw the tail pipes throwing alot of exzaust smoke. tip buy a can of carb cleaner or brake fluid and start the stang unplug the vac cable that runs from you brether to your throatle body and spray all the can or brake fluid so that you can clean out your valves intake and etc, at first you will see black smoke come out of you tail pipes and you need to flour it so that it wont shut off and as you keep repeting these steps there will be no more black smoke you just cleaned your valves
