does the four link really suck?
  • Thread starter Thread starter njoliver
  • Start date Start date Jun 27, 2010
1 of 2 Next Last
N
njoliver
259
Columbus OH
Jun 27, 2010
  • Jun 27, 2010
I have heard from numerous people and companies that four link is a out dated suspension and it just sucks. I am building a road race mustang and have a adjustable four link set up...think it is going to suck. I heard the best is a torque arm set up. I heard that the four link will bind no matter what and you will never know what your car will do when going into the turns,
281pony
2,681
Oly, WA
Jun 27, 2010
  • Jun 27, 2010
get an irs then. or contact MM and get your parts.
W
WLDHRSE
701
Elkton, MD
Jun 28, 2010
  • Jun 28, 2010
Just curious, are you refering to the factory 4-link, or a sub-frame & 4-link w/ coil-overs?
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jun 28, 2010
  • Jun 28, 2010
It's not that it's BAD, it's just not as good for the twisties as a panhard bar/torque arm setup. A 4 link is better suited for drag racing.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jun 28, 2010
  • Jun 28, 2010
Yep, go torque arm and never look back
N
njoliver
259
Columbus OH
Jun 28, 2010
  • Jun 28, 2010
yea thats what I heard it is perfectly fine for drag but for turns your way better off with a torque arm. I have a pretty nice rear end set up atleast i think i do...have not used it yet. I spent alot of money on it, if I dont like it I will probably to the torque arm set up this winter.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jun 28, 2010
  • Jun 28, 2010
N
njoliver
259
Columbus OH
Jun 28, 2010
  • Jun 28, 2010
http://www.backwater-productions.net/_images/_Usenet/Graphic_Design_-_Here_Is_Your_Tampon_1.png
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jun 28, 2010
  • Jun 28, 2010
uhm its was a joke, something you go, haha, at
W
WLDHRSE
701
Elkton, MD
Jun 28, 2010
#10
  • Jun 28, 2010
  • #10
Steeda has a 5-link conversion that was supposed to be pretty nice for road race types. It made the UCA's parallel to the lowers, and added a panhard bar.
Torque arms are good and not too expensive. Maximum Motorsports and Global West have good options there. You could also run a stock type setup with heim's in the UCA's at the housing end.
If your looking for the best road race rear suspension, lookup/contact North Race Cars about a Watts Link.
What is your current setup?
If you are
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jun 28, 2010
#11
  • Jun 28, 2010
  • #11
If you are
The 5 link is a glorified panhard bar
N
njoliver
259
Columbus OH
Jun 28, 2010
#12
  • Jun 28, 2010
  • #12
I was joking with you. when I first looked at it I did not get. I get it now
T
thethirdeye88
113
paragould arkansas
Jun 28, 2010
#13
  • Jun 28, 2010
  • #13
i got the koni single adjustable/H&R springs, MM lowers, FRPP uppers, MM panhard bar, with MM tubular A-arms on my 95...unfortunately, everything is still in the box, but i am doing a road race/autocross setup and feel completely confident with anything you will be able to throw at the car...
call Maximum Motorsports and talk to jason...before you call, write down all the questions you want answered and once you get ahold of jason, let the questions rip...every question will be answered and he will not just try to sell you parts...
BPA
159
S.F.
Jul 1, 2010
#14
  • Jul 1, 2010
  • #14
WERD
Go to the MM website and read up a bit the benefits. Then buy either MM or Griggs depending on the money you have to spend.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jul 1, 2010
#15
  • Jul 1, 2010
  • #15
BPA said:
WERD
Griggs is not meant for ANY type of street use BTW
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jul 1, 2010
#16
  • Jul 1, 2010
  • #16
You're aware that what you have is still 4 link right?
N
njoliver
259
Columbus OH
Jul 1, 2010
#17
  • Jul 1, 2010
  • #17
I talked to jason before I ordered all my stuff and he suggested the torque arm set-up for road race, especially in a high horsepower application. the problem with roadracing a 4 link is that the rearend can do things you dont want it to when going through turns making the car unpredictable.
G
GDTrumbo
199
Nashville, TN
Jul 2, 2010
#18
  • Jul 2, 2010
  • #18
^ Especially w/o the panhard kit. The "rear steer" syndrome sucks.
Dino Dino Bambino
1,673
90
79
Cyprus
Jul 2, 2010
#19
  • Jul 2, 2010
  • #19
The weak links in the rear factory 4-link are the control arms. Getting rid of the factory lowers with the squishy rubber bushings is the first step. If you replace them with lowers that have spherical bearings at one end e.g. MM, that'll reduce suspension bind and make cornering more predictable. You might even be able to get rid of the quad shocks at this point and still not have wheel hop upon launch.
You then could do coilovers and reduce unsprung weight but that doesn't address the real weakness which is now the factory uppers. The question then becomes what to do next? You could do:
1. Adjustable uppers with spherical bearings at the axle end e.g. Edelbrock as I did. You'd still have a 4-link but these will further reduce suspension bind and reduce lateral axle movement. Handling becomes more predictable with improved grip exiting corners and less risk of snap oversteer. You can also adjust pinion angle. A simple, cheap fix but there's better.
2. Watt link. You can do away with the upper control arms altogether and you now effectively have a 3-link. Excellent, neat, but you'll need a side exit exhaust 'cause there's no room for tailpipes.
3. Torque arm/Panhard bar. Also effectively a 3-link set-up, also excellent, but requires subframe connectors with crossmember to mount front end of torque arm. Adds a lot of weight, reduces ground clearance, and you need to modify the midpipe for clearance.
4. Steeda 5-link. A neat idea really. With the upper control arms now parallel to the lowers to control axle rotation and a panhard bar to prevent lateral movement.
N
njoliver
259
Columbus OH
Jul 3, 2010
#20
  • Jul 3, 2010
  • #20
I have MM extreme duty Rear lower control arms and pro-link uppers and they are spherical rod ends...pro-link have some really sweet control arms I can adjust my pinion angle and on the diff side I have different control arm mounting locations to change my instant center So I have been thinking of adding a panhard bar. doe it help cornering control?
1 of 2 Next Last
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
