my car idles kinda high.. i have that little screw, back all the way out to where it dont touch.. isnt that where your supposed to adjust the idle?? but neways it still idles high.
Well, if the little screw isn't touching at all then your butterfly isn't open at all and your car technically shouldn't idle at all (because it's not getting any air w/ the butterfly closed - the IAB/IAC doesn't work at idle) unless you have a major vacuum leak, have holes drilled in your butterfly, or you have one of the idle adjuster plates w/ the two little screws (basically a controlled vacuum leak).jstang209 said:my car idles kinda high.. i have that little screw, back all the way out to where it dont touch.. isnt that where your supposed to adjust the idle?? but neways it still idles high.
Look at the link James put up. Each page addresses a different aspect of cleaning and setting idle adjustment componentry.jstang209 said:how do u readjust your TPS.. my idle is over 2k, so i know thats not normal
jstang209 said:im not trying to be rude but if u read i just said.. i cant get the idle down.. it wont go below 3k..the wierd thing is.. when i press the gas the idle goes down and the car dies..
marine_2003 said:The timing does play a factor in your idle, loosen the nut for your distributor with the car running, slowly turn the dirstributor to the left or right, you should be able to hear the idle adjust as your turn the distributor.
THAT CRAP HURT!!
