- Oct 9, 2003
- 968
- 1
- 17
On a stock T-5, if you pull out the driveshaft yoke, can you move/wiggle the mainshaft (output shaft) laterally with a screwdriver? Is there some give in there, or is it supposed to be rock solid?
After looking through the rebuild manual, it doesn't look like there is a bearing in the tailhousing at all. Just the bearing between the input shaft and the bearing at the case between first gear and fifth gear. Then the output shaft hanging way out through the tailhousing.
Rick
Rick
