Does this sound right?
Temp sounds about where mine is
idle - sounds a touch low but not real low
ign timing- huh ???
battery - sounds good
A little more info might get you some more responses. Like is it a 5spd or auto, what's done to it, why did you run a scan, are you having any issues, and so forth.
Temp is fine,idle is perfect for a N/A car but not sure bout an SC one. Timing seems a bit low but that's probably best for the blower. The voltage is a little low as well. It should be closer to 14v most of the time but it's not a big deal either.
