ok i was looking at my t5 parts today and wasnt sure which one was the actual 4th gear blocker ring. i look on a service manual and i found out the ring that falls off is the blocker i think.
on the input shaft there is a tapered roller bearing, the drive her on the shaft and ring with some dog teeth, and then a bearing race and the loose blocker ring that it blue and comes off easily. the blocker ring teeth are fine, the teeth of the ring thats part of the input shaft gear are the ones that are worn.
does this gear come off or will i have to replace the whole input shaft??
