Doin a/c Delete with FMS Kit - Removing Bolts..
woooo thats a reallly biiatchhhhh.....do the double nut trick...out if yours was like mine that wont fully do the trick...be prepared with a blow torch and a hammer to tap it a little...mine ended up being bent on the end....
Heres what i did....stood on pass side and pulled,(once the double nuts were reallly tight) but the stud was gonna snap (was bending)....so while your reaching and pulling, u gotta get a hammer and hold that against the stud to stop it from bending....thats BARELY got mine out
But hopefully u wont have a mess like me :D
Good Luck
that long ass stud might also pull out the insert that it's screwed into. Depends on how rusty it is in there. Mine came out so I bought a HUGE ass bolt to attach the ac kit. If this happens to you, buy the big bolt and open up the hole in the ac kit a bit to clear the new bolt. Good luck!
