  • SN95 4.6L Mustang Tech
Doing Mongoose Install...Need help
  • Thread starter Thread starter blacknblue2002
  • Start date Start date Apr 8, 2006
blacknblue2002
159
Va Beach, Va
Apr 8, 2006
  • Apr 8, 2006
ok...been working on the install when I get time....I'm pretty far along, but I've run into a tiny snag. The Lightning MAF doesn't work with any of the pipe connectors that come with the Vortech kit, and I can't find anything that would work that came in the box from Modular Powerhouse. How does everybody make the Lightning MAF work with the Vortech Piping...can I find a piece of hose at Home Depot to make it work...How did everybody else do it? Thanks in advance for info.
As a side note...this install has helped me learn a lot about the car (fuel pump, spark plugs, fuel injectors, and all of the intake stuff). I'd recommend doing it yourself if you don't have much mechanical skill, just for the fact that it will force you to learn more about your car. I know nothing and I've been doing allright so far.
01Steeda
732
Baton Rouge, LA
Apr 8, 2006
  • Apr 8, 2006
subscribing. I will be going this route soon.. hope you get an answer
san~man
O-G
A little grass shack on a big lava rock
Apr 8, 2006
  • Apr 8, 2006
Post this on Tim's website...I'm sure you'd get a faster response there.
Good luck.
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Apr 8, 2006
  • Apr 8, 2006
Good luck.
:Word: Free tech post ftw!
blue46gt00
83
  • Apr 8, 2006
Did you get a 4" boost pipe?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 8, 2006
  • Apr 8, 2006
Billet MAF Adapter
http://www.lasotaracing.com/Late model maf.html
helty
Mar 30, 2005
1,461
Baltimore, MD
Apr 8, 2006
  • Apr 8, 2006
urban96 said:
Billet MAF Adapter
nice link
BennyBlown2v
1,233
Carmel, INdiana
Apr 8, 2006
  • Apr 8, 2006
urban96 said:
Billet MAF Adapter
Vortech kit comes with MAF -> Filter adapter (really nice one actually, bolts into the inner fender).
Did you try using the stock flex-pipe and everything? Hmm...you could just (as ghetto as it sounds) tape it up! Use whatever coupling comes closest, and then just tape it for the time being? Or...buy a boost pipe and have Tim send you a new tune
Green&GoldGT
302
Virginia
Apr 8, 2006
  • Apr 8, 2006
How hard is it to install the fuel pump or chip? Do u need ramps or a lift for the fuel pump? I'll probably go with the powerdyne but i dont know if i should install it myself or get it installed at MAS Racing, im sure u know the place here in VB. Good luck with the install
the98stang
2,408
Clovis, CA
Apr 8, 2006
#10
  • Apr 8, 2006
  • #10
Most of these kits are fairly easy to install. You could probably do it yourself. The tune is the most importany, but if MPH is sending you the tune, you'll be all set
The tuner sent with the Mongoose Vortech kit (Xcal2) plugs directly under your dash. And I believe the fuel pump is located under the back seat bottom cusion, but dont quote me on that.
BennyBlown2v
1,233
Carmel, INdiana
Apr 8, 2006
#11
  • Apr 8, 2006
  • #11
Too bad
Fuel pump is located IN the fuel tank. You'll need to jack the car up in the back and put it on some jack stands (1' is plenty high). You remove four bolts holding the tank retaining straps on, three bolts in the filler neck, lower it down a bit, disconnect the fuel line at the filter, and then drop the tank more. Open up the sucker, being careful not to drop any bolts, open up the fuel bucket (5mm screws), replace the pump, put it all back together, and you're done.
hotmustang331
2,967
Bastrop,TX
Apr 9, 2006
#12
  • Apr 9, 2006
  • #12
^Off topic, but how do your coilovers ride? Does it feel kinda rough over bumps and like vibrate the dash when you hit sudden bumps? Oh and I do have coilovers, just wondering how yours act....I dont know if this is normal.
the98stang
2,408
Clovis, CA
Apr 9, 2006
#13
  • Apr 9, 2006
  • #13
BennyDaBall said:
Too bad
I know that sounded stupid lol, but the fuel pump in my mitsu 3k was accessable through the trunk. I was wrong
USMC03GT
144
Jacksonville, NC
Apr 9, 2006
#14
  • Apr 9, 2006
  • #14
C'mon now, this is an american car. Nothing is easy or simple.
sgarlic
3,085
Apr 9, 2006
#15
  • Apr 9, 2006
  • #15
The 05+ are accessible by removing the back seat cushion.
blacknblue2002
159
Va Beach, Va
Apr 9, 2006
#16
  • Apr 9, 2006
  • #16
The coilovers ride super rough...I've got mine resting pretty low right now...my back tires rub with 285's and I don't have the full range of turning on the fronts...looks sweet, handles great, but will chatter your teeth on a seemingly smooth road
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
