Finished the tranny swap today!
For the most part, anyway. I need to get an adjustable clutch cable, firewall adjuster, and quadrant (or some combo of the above) because the JY cable I got is stretched a little. Need to finish up the sound deadening in the shifter hole, and unhook the cable in the steering column that went to the shifter (prevent it from starting in Drive? dunno). Some tips:
- Yes, you can use the A4LD starter index plate! All you have to do is cut away the bottom left hole so it fits the bell, and you're good to go.
- Yes, you do have to cut metal away from the shifter hole. Do it with the tranny OUT of the car, it's much easier that way.
- If you remove the entire line that goes to the vacuum modulator on the A4LD, don't forget to plug the vac hose where it used to be - your idle will be screwed up if you leave it open.
- You can use a Turbocoupe clutch and pressure plate as long as you also use a TC flywheel. It's very grippy - how much grippier than a n/a clutch, I can't say, but it's definitely nice. I left a nice set of snow-stud grooves carved into the floor of the VW garage we used.
- And finally, if you possibly can, get a lift and air tools, as well as someone who knows what they're doing. My buddy Kyle from my Mustang club is a tech at a VW dealer, and also knows his 2.3's (and his Cummins stuff, so he and my dad get along well
), and he was a lifesaver. Many thanks to him.
Gotta wait till I clear out my other attachments
to see a pic.
Ash
For the most part, anyway. I need to get an adjustable clutch cable, firewall adjuster, and quadrant (or some combo of the above) because the JY cable I got is stretched a little. Need to finish up the sound deadening in the shifter hole, and unhook the cable in the steering column that went to the shifter (prevent it from starting in Drive? dunno). Some tips:- Yes, you can use the A4LD starter index plate! All you have to do is cut away the bottom left hole so it fits the bell, and you're good to go.
), and he was a lifesaver. Many thanks to him. Gotta wait till I clear out my other attachments
to see a pic. Ash
.... i need a short-throw......
