Door Guts Swap Possible?
Taranis
92
Austin, Texas
I just bought the shell of a '69 mach1 and one of the things that I'm going to have to put in it is the door guts (window gears, etc...)
Will the guts from the door of a '68 coupe swap into the '69? Even better if someone knows if the door windows can swap over as well.
Thanks in advance for all who reply.
If I remember, the 1970 door glass was bolted in because the 69 glass was a problem with coming out of the track. Verify this before you buy...the 70 is probably what you want to look for.
yeah the 68 stuff will absolutely not work. the 70 stuff, however, is a direct swap and you get the bolt in glass as well, plus if you ever decide to add an aftermarket power window setup you'll need the 70 stuff anyway.
