downshift grindd
  • Thread starter Thread starter 00GTpony
  • Start date Start date Apr 27, 2008
00GTpony
162
  • Apr 27, 2008
Ok so all the sudden my car wont let me downshift into second without it grinding like crazzzzzyyyyy... if i want to down shift into second it will go in but with a rele bad grind and clunk. If im driving normal i can shift 1, 2, 3, 4, fine. Its only downshifting. What do u guys think.
Fluid Problem?
Rebuild?
- also i had just raised the idle on my car with the diablo from 700 to 900.. could that be why?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Apr 27, 2008
  • Apr 27, 2008
Clutch probably isn't disengaging all the way. The higher idle RPM shouldn't be an issue. See if you can adjust it. Depress the pedal then lift up toward you with your toe. You may hear a click when it adjusts. If it doesn't help it could be that it is already adjusted all the way. As the cable gets older it will stretch. You could get a new cable or a firewall adjuster.
40th GT
916
Lawrenceville, GA
Apr 27, 2008
  • Apr 27, 2008
:Word:
And make sure you are rev-matching.
MyBloodRunsBlue
127
  • Apr 27, 2008
i'm having the exact same problem but with higher gears...when i downshift from 5th to 4th it will grind every once in a while....i got a new clutch cable and firewall adjuster maybe i need a new clutch??
J
jprovence
195
Albany, OR
Apr 27, 2008
  • Apr 27, 2008
yeah rev match when you down shift, that will save the clutches from further wear.
MyBloodRunsBlue
127
  • Apr 27, 2008
what ya mean rev match?
Black_02_GT
Mississippi
Apr 27, 2008
  • Apr 27, 2008
i would assume he means when going from say 4-3 to give it a little gas to bump the rpms up to where they should be for that gear compared to the mph... less stress on the clutch i would guess but would it make that much of a difference?
J
jprovence
195
Albany, OR
Apr 27, 2008
  • Apr 27, 2008
It makes all the difference in the world. It does a few things. One, its a road racing trick, it avoids upsetting the balance of the car when down shifting. Not much use on the road, but makes the shifting smoother. Two, the clutch and the syncros take the brunt of the force when a down shift occurs when the engine is spinning slower then the drivetrain. Rev match will match the RPMs of the rest of the drive train saving the syncros in the transmission. Ever drop from 5th to 3rd on the highway? yeah your syncros took a hard hit. Try hittin 4k, then hitting 3rd.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Apr 27, 2008
  • Apr 27, 2008
Blip the throttle so that when you let the clutch out while downshifting the flywheel and clutch are going to the same speed.
For example, on my car, the gears are roughly 1000RPM apart. 3000RPM in 2nd would be 2000RPM in 3rd.
So i'f i'm doing 2000RPM in 3rd and want to downshift to 2nd, i'll push the clutch in, shift to second and blip the throttle up to about 3000RPM and then let the clutch out. If i do it perfectly. you don't even feel the shift and only the change in RPM's gives you a hint i've shifted.
40th GT
916
Lawrenceville, GA
Apr 28, 2008
#10
  • Apr 28, 2008
  • #10
Yep, and your synchros will thank you if you can blip the throttle as you are moving the shifter.
00GTpony
162
#11
  • Apr 28, 2008
  • #11
i guess im rebuilding it huh
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
