  • 1994 - 1995 Specific Tech
Dr. Gas?
  • Thread starter Thread starter 95WhiteVenom
  • Start date Start date Apr 17, 2005
95WhiteVenom
624
Alabama
Apr 17, 2005
  • Apr 17, 2005
Ok I just got a Dr. gas X-pipe. I will be getting BBK LT's soon. I however will not be doing the install. I will be putting a heat shield over the starter. My question is how has LT's changed your car? Noticeable difference? Power in higher or lower rpm's?
LoudToy958
435
Bremerton, WA
Apr 17, 2005
  • Apr 17, 2005
Glad to see you got the X-pipe,
as far as the difference with LTs, I didn't notice any low end difference at all really. It did kinda quiet down the idle and lower rpms though. Once you get on it, it screams, and you will notice the higher rpm difference. Especially with the o/r x. I am sure once you get on it the first time it will put a smile on your face.
95WhiteVenom
624
Alabama
Apr 17, 2005
  • Apr 17, 2005
im sure it will shane ohh btw you ever notice that the invoice says dr. gas X pipe for mac headers?
D
DaveB
637
Middlesex and Pomona, NJ
Apr 17, 2005
  • Apr 17, 2005
I went for the stock h-pipe and headers to a Dr. Gas offroad x and BBK LTs. Very noticable power increase from 4k+. There was a slight torque drop below 2k, but that really isnt that bad. Big change is in the sound. Once you hit 4k rpm the exhaust just screams . And the sound at idle is nice too. I always get compliments.
LoudToy958
435
Bremerton, WA
Apr 17, 2005
  • Apr 17, 2005
It is the same part. For the BBK, there are 2 small sections that you have to use, that are in the box. It fits both sets. I called and asked because I did notice that. He said the Macs are just a little longer, so they include those extensions for the shorter BBKs.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 17, 2005
  • Apr 17, 2005
How is the quality and fit of the dr gas pipes? I was thinking of going with 1 3/4" Hooker longtubes for my 347 and so I need a 3" mid pipe and a few guys have told me to get a dr gas pipe. Does it 'have' to be welded?
95WhiteVenom
624
Alabama
Apr 17, 2005
  • Apr 17, 2005
yes it has to be welded. Its good quality and also in a small box saves on shipping. I don't have my long tubes so as far as fitment i dont know. I bought mine from loudtoy958
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 17, 2005
  • Apr 17, 2005
I've been told you can clamp it and it'll be fine. But once its together and fitted 100% I could take it off to be welded.
95WhiteVenom
624
Alabama
Apr 17, 2005
  • Apr 17, 2005
I dont know if i would trust clamping, but doing it till you got it fitted would be fine then weld it.
T
TMC
1,426
Chicago
Apr 17, 2005
#10
  • Apr 17, 2005
  • #10
I wouldn't clamp it...there are simply too many parts to it to trust doing so. Perhaps clamp it just to hold it before you tack it into place to pull down and weld up but that's all.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
K
Console Heat after MGW shifter install
  • KirkACola
  • Sep 24, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Sep 24, 2025
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
