Drag Racing Help
  • Thread starter Thread starter stang87306
  • Start date Start date May 27, 2012
1 of 2 Next Last
stang87306
29
  • May 27, 2012
Ok I posted a while back about a project I had going on now I've got it running and driving but the time slips are extremely slow I have a 87 lx hatch w a 306 5 speed it ran a 15.750@92mph that's fare from where I want it need help
lxman
279
Avondale, AZ
May 27, 2012
  • May 27, 2012
what is the set up you are running?
Venom351R
4,548
41
98
MAINE
May 27, 2012
  • May 27, 2012
what goal are you trying to get? What was your 60' on the run? Were you using street tires?
lxman
279
Avondale, AZ
May 27, 2012
  • May 27, 2012
We cant really help you if we dont know these things, sorry bud. anything at this point would be an extreme shot in the dark.
stang87306
29
  • May 27, 2012
I'm sorry I should been more thorough I've got a sbf 306 it has a 10/1 compression all new but stock bottom end w cast dome pistons afr 185 heads that's ported and polished roller rockers lunati 51025 rollor cam parker funnel web and a netted 600 cfm holley new t-5 trans 355 gears w moroso drag springs 70/30 shocks and lake wood lift bars
stang87306
29
  • May 27, 2012
My goal is low 11s for now
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
May 28, 2012
  • May 28, 2012
Stock you should be pulling a 14.5 or so. Does the car feel like its fast. Or is it not running right? I would think you would be in the 12's with that combo with a decent driver.. My guess is something isn't setup right.. Even if your 60 ft times suck your mph should be at least 100 mph with your setup. Your heads might be a little big for a 306, you will have to spin it higher to get all the power out of it. I'm building a 393 and was recommended to get 190cc runners by the guy who built the heads.
stang87306
29
  • May 28, 2012
On the street it feels like its pretty fast I had a 93 cobra that had a lot done to it and it was in the low 12s. And to me it feels like this car is faster but the times are not showing it honestly I have a lot of money in this car and could prolly tack it up higher but don't no how high I can go safely i also have spray but don't no how much the cast pistons will take
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
May 30, 2012
  • May 30, 2012
Where are you shifting the car? Might wanna take it to a shop and just get 3 pulls on on the dyno just to see where you are at. Cause if you think it's running good it should be much faster than the timeslip is showing.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
May 30, 2012
#10
  • May 30, 2012
  • #10
Plus you could see where the motor stops making power, so you have a better idea where to shift.
Rick 91GT
Mustang Master
95
99
PA
May 31, 2012
#11
  • May 31, 2012
  • #11
The Funnel web is killing it, that intake is great for 4000-9000rpms and the low mph indicates the motor is not making power. Can you post a timeslip or the incrementals?
Personally a rpm air gap would be fine on that combo and would give a much broader torque curve, and the car needs more gear 3:55s are not going to get you to your goal. What do you have for headers and exhaust?
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
May 31, 2012
#12
  • May 31, 2012
  • #12
yes I agree.. If the motor was making the proper amount of power the mph would be well past 100 mph..
lxman
279
Avondale, AZ
May 31, 2012
#13
  • May 31, 2012
  • #13
Yeah you are going to need better gears and intake. are you running a stock t5? a stock t5 is only good up 330 ft lbs. if you are going to drag race you will need to upgrade your tranny as well. I would recommend a tko 600 with the shift kit. the shift kit has corbon fiber lininngs on the inside of the brass syncro and the stock plastic shift keys are replaced with brass ones. with this you can actually take it to the track and speed shift it without using your cluth. This will also cut down your time as well. We have guys doing this all the time and no probloems. plus its rate to 600 ft lbs of torque so you wont break it.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jun 1, 2012
#14
  • Jun 1, 2012
  • #14
I've seen t-5's take abuse.. I've also seen them not.. Drive it till it breaks.. Maybe it won't..I replaced mine with a g force t-5 cause I shredded 3rd gear..
stang87306
29
#15
  • Jun 5, 2012
  • #15
Thanks for the info I can't find my time slip but I am in the process of putting 373 gears in it then I'm gonna take it to the dyno and get a better idea I have added a 150 shot lol I'm not sure were I was shifting probaby to low rpm due to the fact my tack stopped working right and my buddy I ran against has his slip supposed to give it to me he said I was wrong my mph was 102
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jun 6, 2012
#16
  • Jun 6, 2012
  • #16
102mph is a low 13 second car... Much better than a high 15 car..
Sharad
ALWAYS choose the V over the P!!! Wait... what?
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Jun 6, 2012
#17
  • Jun 6, 2012
  • #17
Two things, 15.75 means there is an obvious lack of traction (unless you're just creeping off the line) and 102mph indicates that the engine is not making as much power as it should. What city are you in, Stang87306?
stang87306
29
#18
  • Jun 7, 2012
  • #18
I am located in gadsden al
Sharad
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Jun 8, 2012
#19
  • Jun 8, 2012
  • #19
Do you race in Birmingham? I was trying to think of where there may be a local shop to help you with your setup.
stang87306
29
#20
  • Jun 9, 2012
  • #20
I race at Steele but have spoke to a shop in bham hinson motorsports they have a dyno I plan on going there middle of the week
1 of 2 Next Last
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
