  • 1994 - 1995 Specific Tech
Drag Springs
  • Thread starter Thread starter KrazZ27
  • Start date Start date Sep 29, 2008
KrazZ27
83
  • Sep 29, 2008
Converting my car from road race to drag suspension any idea on what springs to get i was looking at the eibachs just didnt know if they were any good please any info would help.....
Stopsign32v
394
Gville, SC
Sep 29, 2008
  • Sep 29, 2008
Start with tires first. Get some 15x10" wheels of your choice and wrap them in 26x10 ET Drags. You probably don't have the power to justify "drag springs". I was lifting the front 17" wheels off the ground with a set of Eibach Prokit springs in the front and rear. Dumping the clutch at 7,000rpms on a set of 26" ET slicks and pulled a 1.56 60'. Try the tires first.
KrazZ27
83
  • Oct 1, 2008
i already got tires i got a 331 stroker with all goods got the basic foundation just need the springs any idea on which ones would be the best
Yellow302
789
NJ
Oct 1, 2008
  • Oct 1, 2008
i just pulled out my broken rear springs from the eibach drag kit. I am switching to the pro kit now... it hooked like s h i t
KrazZ27
83
  • Oct 1, 2008
right now i got the sportlines in and its too low cant even get a jack under the car properly i heard i eibach drag springs were one of the best do know what other brands there are?
Stopsign32v
394
Gville, SC
Oct 2, 2008
  • Oct 2, 2008
What tires? What is your 60'?
Killercanary
The car that set the bar.
Altoona, PA
Oct 2, 2008
  • Oct 2, 2008
I personally would go with coil-overs up front with adjustable struts and something like a FMS B, Mach 1, or Bullitt rear spring. This is a very popular combo choice for a reason. I run a similar combo on my car with 14" 175lb springs set just a little lower than stock ride height (this helps to store a good bit of energy) and bullitt springs out back with strange adjustable shocks/struts all around.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
