Drag Tranny Theory
  • Thread starter Thread starter 7991LXnSHO
  • Start date Start date Feb 5, 2014
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Feb 5, 2014
  • Feb 5, 2014
At what point does it make sense to run a two speed power glide over a three speed auto? It seems to me if there is enough power to blow away the hides in first, installing shorter rear gears (3 something instead of 4:11) would still allow 3 areas to be in peak power/torque at the track. It will also lower your highway rpm if you went on drag week or a cruise. Going to the extreme, a CVT would be ideal if the rubber bands were strong enough. You could always have the motor at peak HP or torque. What am I missing here?
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Feb 5, 2014
  • Feb 5, 2014
I had a friend with a turbo cat making about 1000 rwhp and runnin 8.60's and he switched to a glide because the car was very violent and hard to control on the 1-2 shift. I made the car much more drivable for him down the track.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Feb 5, 2014
  • Feb 5, 2014
There is a lot more theory here that you are thinking. The powerglide isn't the end all be all when it comes to high power cars. I know plenty of guys that run TH400 based transmissions and have gone well into the 6 second zone at 200 mph+. There is also a 2 speed TH400 out there that a lot of the outlaw guys have been trying. Each has its own benefits and different selection of gear ratios power management also comes into play quite a bit. As far as street driving like drag week this is a moot point because high gear is 1:1 in all of the aforementioned transmissions.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Feb 5, 2014
  • Feb 5, 2014
Youd be surprised at how many guys dont run overdrive transmissions on drag week. It helps but its not really needed. Especially since there isnt much highway driving at the event
rbohm
6,698
550
204
tucson,az
Feb 5, 2014
  • Feb 5, 2014
when selecting a transmission for drag racing, you first need to know your engines power band. the wider the power band, the fewer gears you need. a power glide is great for wide power band engines. if you have a narrow band engine, then you want more gears to stay in the narrow power band.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Feb 5, 2014
  • Feb 5, 2014
Lots o factors here. The most important one is power to weight ratio. a glide is more ideal in a lighter car with a lot of power. There is a specific hp/ton ratio where a glide becomes beneficial. I'm not sure of that number. Power band is also a factor.
Kurt
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Feb 6, 2014
  • Feb 6, 2014
to me it comes down to the SLR and what you need RPM and MPH wise.
for us to run out the back with the rear gears we have we need to turn between 92-9500RPM and shes really not to happy at those RPM's
but to run 1/8 mile shes pretty happy.
the solution? go to a shorter first gear aka TH400 and kill some of the rear gear. so the first gear drive ratio is the same and the rear gear is high long enough that we dont have to spin her so high. but we are talking around 10K to do all that between a TH400 converter and all that crap to do the swap
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Feb 6, 2014
  • Feb 6, 2014
What gearset is in the powerglide you guys have now?
srtthis
5,129
1,666
204
Maryland
Feb 6, 2014
  • Feb 6, 2014
1.80 in the turbo car and 1.69 in the nitrous car
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 6, 2014
#10
  • Feb 6, 2014
  • #10
SLR? What are you referring to?
srtthis
5,129
1,666
204
Maryland
Feb 6, 2014
#11
  • Feb 6, 2014
  • #11
starting line ratio
Roanstang
105
10
29
Coastal Texas
Feb 6, 2014
#12
  • Feb 6, 2014
  • #12
SLR, I learn something every day,Thanks.
Reactions: A5literMan
srtthis
5,129
1,666
204
Maryland
Feb 6, 2014
#13
  • Feb 6, 2014
  • #13
some numbers to explain it better
TH400 first gear 2.48
glide has a 1.80
2.48*3.4 (highest gear they make for a 9" pro)=8.432
1.80*3.7=6.66
so the TH400 would give us a better SLR
top speed of the TH400 at 9500 and 5% converter slip (drive shaft speed of around 9000RPM) = 222mph
top speed of the glide at 9500 and 5% converter slip (drive shaft speed of around 9000rpm)= 204mph
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Feb 6, 2014
#14
  • Feb 6, 2014
  • #14
glide has a 1.80
1.80*3.7=6.66
All hail the math wizard!!!
Reactions: krazedstang and srtthis
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 6, 2014
#15
  • Feb 6, 2014
  • #15
And what does it say about me when I smiled when I read "Drag Tranny"
rbohm
6,698
550
204
tucson,az
Feb 6, 2014
#16
  • Feb 6, 2014
  • #16
that you are weird. which means you fit in here quite well
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Feb 6, 2014
#17
  • Feb 6, 2014
  • #17
Agreed!......lol
Bullitt347
I have been doing it wrong this whole time
4,068
3,142
204
Middle of Maine
Feb 6, 2014
#18
  • Feb 6, 2014
  • #18
I ended up going with a Glide because I could not get a Ford Auto to take the power/torque. Plus the added benefit of overall lighter weight, (about 70 lb less than an AOD or 4R70W) less HP loss to spin the trans and the real plus was the Glide can come with a SFI case, so the trans blanket was not needed. It was a PITA to get the blanket to not interfere with the headers ect. For me the hardest part was putting a GM based trans in a Ford..........and then I realized that the engine does not have 1 part in it made by Ford, all Ford based, but not one single Ford made part. Same with the Trans, GM based, but not 1 GM made part is used.
Reactions: hoopty5.0
rbohm
6,698
550
204
tucson,az
Feb 6, 2014
#19
  • Feb 6, 2014
  • #19
these are the main reasons a glide is used most often in drag racing.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
  • dan50
  • Jul 18, 2026
dan50
