I need to change out the upper radiator hose and was wondering if i would need to drain any of the coolant to do this? Also is there any other advice for changing the hose? Thanks
what they said...drain a little from the bottom of the rad till you can squeeze the rad hose with no problems, then, when you pull the upper rad hose connection from the rad, just aim it up and pour anything left back the other way
