Drain plug leaks
how much slop is on the bolt if you tighten it halfway and try and move it around?
on my canton pan it will maybe give a small drop here and there, but it sounds like the threads are way out of tolerance on the oil pan. They do sell oversized drain plugs too.
Surprisingly tight. Wouldn't surprise me if the threads in the pan were actually messed up though.
I'm surprised you're having that much trouble. Teflon washers usually do the trick. If you do use silicone, use ultra black under the hexhead. Be carefull on the threads- I actually have had oilpumps lock up from stray chunks of silicone that got away. It doesn't take much to do it,trust me. Be sure to degrease the surfaces with brakeclean or something that will flash off and leave it dry.
IF none of that works, there's an old millwright's trick. Go to the hardware store and get some lead fusewire. Wrap it around the under the head of the plug and it'll crush forming a seal. It's softer than copper and usually does the trick.
I figure if I get to the point of using silicone, I was just going to make a slight bead under the head. I didn't want to use it on the threads, I don't want any of that stuff in my oil pan. Hopefully the o-ring washers will fix it, I'm going to get some this weekend and try them out.
Hey,
I know it's an old thread but I got here due to a leak. Just wanted to say thank you for your tips! What finally worked for me is the rubber washer and black RTV under the head. Used to leak every day, now 3 days in and all dry!
