  • SN95 4.6L Mustang Tech
Draw through MAF
  • Thread starter Thread starter Night Shifter
  • Start date Start date Nov 10, 2010
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Nov 10, 2010
  • Nov 10, 2010
I have 95mm Pro M/Pmas mass air meter that i plan on using in my M112 build....i was wondering if i can use it though because it was calibrated as a draw through setup...it was originally going on a turbod 2v and the meter was going to be in front of the turbo
since the meter is going to be before the eaton when it goes on the car wouldnt that still be considered a draw through set up? if not, can i have my tuner correct this through the tune?
Three50won
1,135
64
69
Nov 10, 2010
  • Nov 10, 2010
A blow-thru meter goes on the pressurized side. A draw-thru meter goes on the non-pressurized (inlet) side. If the meter you have was calibrated as a draw-thru then I would guess you should be fine because it's function and air charge does not change.
Three50won
1,135
64
69
Nov 10, 2010
  • Nov 10, 2010
BTW, are you selling any cams...??
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Nov 10, 2010
  • Nov 10, 2010
awesome thats what i was thinking...thanks...
and negative on the cams for now....pm me for what kind youre looking for though if you want
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Pro flow serial number
  • Andresquintana.mma
  • Mar 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2025
Andresquintana.mma
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
