crazypete
All my crevices are greased.
If it works and it can be done "invisibly" then it's not ghetto. You can sacrifice the stick tube and bend it under so the metal tube passes under the headers and exits facing front of the engine. Then this "assembly" is invisible with some neat tucking of hoses. Sure is a lot easier than trying to drill a piece of the engine that cannot be removed without engine lifting.
Yeah, some of the aftermarket FMS timing chain covers for use with mech fuel pumps have a dipstick hole drilled in the PS wing of the tc cover. It's great if you ever wanted an oil fountain or want to engage in a continuous oil change
Actually.......would this not also be another solutiuon? Get an aftermarket TC cover with this dipstick hole and use it as described above. Put a short line from the SC back down the side of the motor to the dipstick hole on the TC cover.
