- Jul 27, 2005
- 53
- 0
- 0
So far I have drilled 174 spot welds. Took about 5 hours. Now Im just going through with a chisel to break them and I will be ready to lift it off. The only really hard welds are the ones where two are welded with in a 1/4" of each other and make one complete weld. Everything else is just tedius. I found the best method was drilling a small pilot hole (but not all the way through) and then taking a normal 7/16" bit and enlarging the pilot hole to just bigger than 3/8". Then I took a 3/8" that I ground to nearly flat and used that to cut through the top metal. Overall I would say I made good progress this weekend.
) drill these out? How do you know how deep to drill so you don't drill through bothe pieces?
