My oil feed line has a tiny leak and drips out oil. Not a lot, but enough to make a mess after a while under my car. I've gone about 2,200 miles on this oil and my dip stick went from the full line to about 3/4 since. So I'm not losing a ton of oil. That's not my concern.
My concern is what's the best way to fix this? Anyone ever have this problem?
I could have sworn you said "drain"
. My bad...on second thought, since its your pressure side, I would get some plumbers thread dope...oil resistant. that way there is no chance of the tape coming loose and blocking the tiny inlet hole. the pipe dope/sealant will fix your issue also...homedepot should have it.
