It is not often that a drive shaft breaks in the middle. They tend to twist there but not break. Especially when talking about 400 to 550hp cars. The weak links are the connection points at the ends. So either the front drops or rear drops based upon which end breaks..
On a one piece shaft you want your loop at the front or middle, not in the rear. This way if the shaft snaps up front the loop catches it before going to the concrete and causing you enormous back half damage by digging in in the same direction of your travel. If the rear snaps, the shaft falls to the concrete and since it is facing away from the direction of travel, it cannot dig into the concrete for more damage.
The loop is really mainly on the car to stop mass tunnel damage and possible passenger compartment entry. If you have ever seen one let go on the big end of the track, you know what I'm talking about. Just imagine having to refloor your mustang entirely.
