Anyone know a good brand to use? and/or one that requires the least amount of install work, so its not a huge pain in the ass.
I bought the BMR rear piece instead of the front loop because it does not require removal of the driveshaft to install and winds up close to the center of the shaft. Either of the BMR pieces should be fine if you have a onepiece drive shaft. If you still have the stock 2 piece shaft you will need both pieces.
If you only get the rear, and your driveshaft breaks at the end of the track, your car becomes a catapult. If you're only going to purchase one or the other, always go with the front. I know mythbusters proved you can't actually launch your car with a broke driveshaft, but you do get quite a bit of air if you hit it right, plus you'll damage your rear end. If you only have a front loop and the one piece driveshaft breaks, the worst that happens is you drag your driveshaft on the cement.
Highly recommending the GMS loop.
It installs using existing studs for the heat shields. No removal of driveshaft necessary because the front loop is in two pieces.
