Driveline angle problem.
  • Thread starter Thread starter jpwindsor
  • Start date Start date Nov 21, 2004
J
jpwindsor
So Cal
Nov 21, 2004
  • Nov 21, 2004
undefinedundefinedHello group, trying to figure out the best way to correct a driveline angle problem in my 65 Fastback. I am running a 95 302, AOD trans with a Windsor-Fox crossmember. The 9" rear axle is from a 59 Ranchero. The rear springs are 4.5 leaf double revese-eye with stock shackles. I measured 1.75 degrees at the rear axle and 4.5 degrees at the trans yoke. The engine mounts are the early-style. If I could raise the back of the trans, I could get a better yoke angle, however, the AODs larger case and extension housing prohibits that. Has anyone else run across this? I know prefered angles to be more than 1 but 3 or less. I have 3 degree pinion angle shims already installed to nose-up the pinion angle. Any feedback would be greatly appreciated. Thanks, Jay
J
JB66
565
New York
Nov 21, 2004
  • Nov 21, 2004
How much can you lower the motor?
J
jpwindsor
So Cal
Nov 21, 2004
  • Nov 21, 2004
I can probably lower motor 1/2 to 3/4 inch, there seems to be that much adjustment to the fan shroud. I can raise the trans only a little more than 1/8 inch.
HyYoSilver
1,339
On a creeper, underneath the car
Nov 22, 2004
  • Nov 22, 2004
Jay, as you probably already know, the driveline angles need to be nearly the same on both the transmission end and the pinion end. (if the pinion angle is 2* [positive], then the trans output should also be 2* [negative]) This holds true for a driveshaft with single u-joints on each end.
It sounds like you need to go down (rather than up), at the transmission output?????(Or am I looking at this wrong....? )Simply dropping the crossmember a bit would lessen the trans angle, and get the two angles more in line.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Nov 22, 2004
  • Nov 22, 2004
That's how I read it too, how is the rear hight? Can you lower the rear?
J
JB66
565
New York
Nov 22, 2004
  • Nov 22, 2004
JP, are you measuring the angles relative to the 2 attached pieces or each piece relative to the horizontal plane (level, zero bubble)? The only way to lessen the angle (make it smaller) is to "straighten" the plane of the tranny to the horizontal plane. No? You said you can only raise the back of the tranny up about 1/8". If you can't raise the back, you have to lower the front.
bk005
10
South Texas
Nov 22, 2004
  • Nov 22, 2004
What is more influential on d-shaft vibes(single cardan), U-joint angle, or keeping both yokes paralel. I worry more about keeping both yokes paralel, or actually keeping my pinion 1* down to comp for torque. If this is right Id just cut and rotate perches to desired.
J
JB66
565
New York
Nov 23, 2004
  • Nov 23, 2004
Isn't the pinion supposed to be angled down? The axle torques the pinion up when you apply power, yes? Also, don't absolutely parallel (0*angles) create more vibration problems? Sorry for all the questions...I may need more learning...
J
jpwindsor
So Cal
Nov 26, 2004
  • Nov 26, 2004
Thanks to all for the replies! With the double reverse-eye springs in the rear, the driveline is going down-hill from back-to-front and it seems that lowering the crossmember would only worsen the angle. I may have to go to a mid-eye spring to restore proper angles, I hope not because the car sits really nice the way it is now.
Route666
1,652
Brisbane, Australia
Nov 26, 2004
#10
  • Nov 26, 2004
  • #10
You need to either raise the crossmember or lower the engine to rais the transmission output.
Where is your diff input pointed? If it's a standard diff that's been lowered and is now higher than the trans output, you'll most likely need to rotate the diff housing so that the angle is ok, and when you apply power it doesn't get even worse.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Nov 27, 2004
#11
  • Nov 27, 2004
  • #11
Took awhile to picture your Problem.
But have you tried placing wedge shims on the backside of the Diff mounts?
What your discribing is reverse of the wedging for lifting 4x4s
to lessen the angle of the pinion.
PB
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
