  • 1994 - 1995 Specific Tech
driver window only goes down sometimes!
  • Thread starter Thread starter juiced_94gt
  • Start date Start date May 29, 2005
juiced_94gt
1,143
Southern California
May 29, 2005
  • May 29, 2005
most of the time now i have to press the switch like 30 time before it's compleatly down most of the time, and sometimes it goes down normaly, what gives? is it the switch or the window motor? has this happened to anybody else? please let me know what you did to fix it. thanks.
95strokerPSU
986
Sacramento from Philly
May 29, 2005
  • May 29, 2005
When you press up does it still make the clicking sound. Similiar thing happen to my rear passenger window. If you take off your door handle bezel and unscrew the switch panel you'll notice that you can seperate it in half (one side will have the wires going into it and other side will have the switchson top). If these two halfs aren't pressed tightly together the proper connection won't be made. Hope this makes sense.
HISSIN50
34
129
May 29, 2005
  • May 29, 2005
when it wont move, check at the motor to see if you have juice getting there. if so, I would suspect the motor. In the FAQ at the top is a write up on swapping the gears inside the motor - they are a trouble area. if you are contemplating a new motor anyhow, makes sense to pop the old one apart and see if you have dust for gears.
good luck.
juiced_94gt
1,143
Southern California
May 30, 2005
  • May 30, 2005
see most of the time its a pain to roll DOWN when i roll it up its fine and it doesent click, it doesent click when going down either and 1 out every 5 tries it will go down fine too...what gives?
95strokerPSU
986
May 30, 2005
  • May 30, 2005
Do your other buttons click? I just checked mine, and they all make a clicking sound (and they all work). So if I was you I'd take off the door handle bezel and check to make sure the screws that hold the switch panel to the bezel are tight. Reason being is that those screws keep the two halves of the switch panel tight together.
If that's not it then I'd do what HIISSIN said and check voltage at the motor.
BDAWK2002
139
Old Bridge N.J.
May 31, 2005
  • May 31, 2005
If the window runs fine once it starts moving it's prolly the switches.I just had the same problem with my 95 and got new swithces from 5.0 resto for like $15.To really be sure you have to check for power at the motor but putting in new switches is easier than popping the door panel if you dont have to.If you can afford it change them all,our cars are 10 years old so the switches are due to start wearing out.
steve hansen
30
  • May 31, 2005
switch going bad no doubt
hoamskilet
90
Belvidere, IL
May 31, 2005
  • May 31, 2005
Try takin your switch apart and just spray some contact cleaner in it and wipe em off. I had the same problem last spring and this fixed it up and has worked 100% since.
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
1996 - 2004 SN95 Mustang -General/Talk- Oct 15, 2026
skidad
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
V
Window rolls down automatically
  • Valicy
  • Apr 30, 2024
3K
1994 - 1995 Specific Tech May 6, 2024
Mustang5L5
