drivers side header install
  • Thread starter Thread starter wrif2049
  • Start date Start date Jun 1, 2010
wrif2049
10
USA
Jun 1, 2010
  • Jun 1, 2010
so I started putting on my header's (Ford Racing Shorty's) and to my surprise they turned out to be easy UNTIL the drivers side. I tried about a thousand different angles and slightly bending the dip stick and getting no were. Since this is my first time doing headers I was wondering if you guys had any tips, it looks like if I could remove the dip stick tube I could install the header then reinstall the tube no problem but I cant find anything on how to remove it. would that be a good way to go?
I'll post some pics once i find my camera
94GTCoupe
1,412
92
79
CA
Jun 1, 2010
  • Jun 1, 2010
i had to install my BBK shorties from under the car.
disconnect the steering shaft and slip it in there.
Vinnietbird
584
  • Jun 2, 2010
My BBK's go in from the top,just drop right in.Pull the dipstick tube gently from the block where it slips in,and then drop the header in.After all that,fit the tube back into place.You may need to clearance the tube bracket where it bolts to the header bolt which is common with aftermarket headers.
KamiKaziDK
555
Mesa, Az
Jun 2, 2010
  • Jun 2, 2010
The dipstick tube should just pull out once it's unbolted from the block, either slide in from above or under the car.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Jun 2, 2010
  • Jun 2, 2010
The dipstick tube is just a friction fit. Once it's out of the way, the header drops right in. It should take less than 20 minutes to accomplish.
wrif2049
10
USA
Jun 2, 2010
  • Jun 2, 2010
thanks for the conformation I will try this tomorrow, I knew there had to be a better way then fighting that thing for 2 hours and since this looks like the best opportunity for new plugs I will be picking up some Motocrafts as well
wrif2049
10
USA
Jun 3, 2010
  • Jun 3, 2010
got the new plugs in and gaped them to .048 and indexed them as straight up as I could without over tightening but the dip stick will have to wait for another day, when you guys took your dip stick out did you use pliers? I didn't try using them because I don't want to crush the tube but it's in there really good, it wiggles back and forth a bit but doesn't want to come out. maybe I'm just being to careful?
KamiKaziDK
555
Mesa, Az
Jun 3, 2010
  • Jun 3, 2010
Up and out man, shouldn't need pliers at all.
Hi-Po
106
Oslo, Norway
Jun 4, 2010
  • Jun 4, 2010
Twist and pull upwards, but be careful - its a pain in the ass if you break the tube.
Pliers are probably not a good idea, you will most likely squeeze the tube and increase the chances of breaking it.
Put on some good working gloves and go for it - gently but firmly
wrif2049
10
USA
Jun 6, 2010
#10
  • Jun 6, 2010
  • #10
well that was easy! I guess I was just being to careful with it and with the dip stick out the header went on in less the 20 min! I can't believe how easy these were with all the help the fours given me. Thanks for all the help.
94GTCoupe
1,412
92
79
CA
Jun 6, 2010
#11
  • Jun 6, 2010
  • #11
good work
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
G
2001 Mustang GT noise after header and control arm (x2) install
  • gilmo5
  • Jan 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 12, 2025
weendoggy
