okay so i have had problems with the rear housing of my transmission leaking fluid, i thought i had it fixed. i replaced the yoke on the drive shaft, the bushing inside the rear housing and the seal of the rear housing. it stopped leaking for a few days and now i have a small puddle of fluid in my driveway again.
the last yoke was bent... crooked... messed up. i am sure it was from the torque being layed down to it. so yeah i have been doing some hole shots and having fun with the car off the line and generally enjoying myself with it. my question is, is this common i am probably only putting out 275 horses, i had help from a member and i think i have 4.30 gears. does this happen do i need to get a stronger driveshaft? could it possibly be something messed up inside of my transmission that is causing this? i plan on replacing my gear box with a better used one but i dont see that having anything to do with the rear housing seal leak.
i have already spent 110 dollars on this issue and its been less than a week of it being fixed. last time the leak was causing the fluid to get tossed onto my exhaust and my car would smoke everywhere i would go. i really need to get this taken care of. any suggestions or answers would be very much appreciated.
