drivetrain vibration?
  • Thread starter Thread starter pistonhead351
  • Start date Start date Oct 17, 2006
pistonhead351
flim hunter
May 1, 2005
75
  • Oct 17, 2006
well i just got done swapping out my rearend. and while i was at it i took that dog bone looking thing off the housing, and im wondering if this would cause any vibration? i dont know what it is because it was fine before the swap. i repostioned the driveshaft around a couple of times and that didnt solve it. ay ideas??
9
90' LX 5.0
59
  • Oct 17, 2006
Put the dogbone thing back?
Glaze
133
Gainesville, GA
Oct 17, 2006
  • Oct 17, 2006
that thing you took off rear end is supposed to limit vibration to a degree. Since you clocked the driveshaft that is good. What is the condition of this rearend you put on? Bearings in good condition? Is there whining noise coming from this rearend when you drive at certain speeds? Is the weight on the driveshaft still intact?
pistonhead351
flim hunter
May 1, 2005
75
  • Oct 18, 2006
yep weights are all still on the driveshaft, brand new bearings, its completely rebuilt except for wheel bearings.
pistonhead351
flim hunter
May 1, 2005
75
  • Oct 18, 2006
im thinking maybe driveshaft needs to be balanced. i switched from 3.55's to 3.73's also. come on if strype made this thread it would be ****ing 20 pages long by now.
Glaze
133
Gainesville, GA
Oct 18, 2006
  • Oct 18, 2006
Did car vibrate before rear end swap? If not than driveshaft probably wont be the problem. Although it might be a good idea to invest an alum driveshaft as they are a whole lot smoother and lighter.
put dogbone anti vibration thing back on and see how it goes.
lastly, what is new in rear end? what is used? Did you mean that the axle bearings are new or not?
pistonhead351
flim hunter
May 1, 2005
75
  • Oct 18, 2006
it is a used rearend however we rebuilt the trackloc and put motive 3.73's in it. all new bearings and races internally but it still has the old axles bearings
Glaze
133
Gainesville, GA
Oct 18, 2006
  • Oct 18, 2006
id replace axle bearings regardless bro....hate to pit up and wear the axle races
throw that dampner on just to see, i dont think ford put something on that wouldnt help it in first place. i read alot that people say to throw it away and it doesnt help, or that its made for that perticular rear end and if its not it wont help. I switched out an 8.8 in mine and resused the dampner and the car is really smooth down the highway (with all new bearings). good luck!
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
