5spd GT said:I just see no "daily driver" need on having a car reving close to 1/3-1/2 its rpm capabilities in the final gear drive on the highway...
perhaps you lack reading comprehension
ITS BARELY MORE THAN YOUR 3.73s!!!
120 rpm
yellow1995Cobra said:Wait till u take a slightly modded cobra for a whip![]()
I like the machs alot, and you can get them new fairly cheap around here, 21-22k out the door it seems, which isnt to bad.
Theres a azure blue mach 1 at my track who is in the 11's, i raced him once, he went 11.7. Not to sure on the MPH, it was fairly low, 112 range maybe. His mach is just bolt ons, but EVERYTHING tubular, no seats, bogarts, so its very very light. But man that thing launchs hard!
) I dont think he will be touching the gears anytime soon just because he did get the 100,00 mile warranty and he's got other vehicles that are a little more extreme. Glad to see this thread took off!! 95snoozer said:perhaps you lack reading comprehension
120 rpm
mystang94gt said:Our local track is pretty fast
I knew it.... you've been cheating!
I just moved closer to another track that is suppose to be faster too. I'll be heading there this spring for a few runs.
gcomfx.com said:I knew it.... you've been cheating!
5spd GT said:Have you ever heard of "little things add up"?
Me? Reading Comprehension problems?![]()
gcomfx.com said:My local track is 910 feet above.
95snoozer said:wow i didnt realize i was talking to someone with a sandy vagina.
you really thing that makes a difference
You really should look at things from BOTH points of view and keep the insults, joking or not, out of it.
Just my random mumblings.gcomfx.com said:You really should look at things from BOTH points of view
obsured?gcomfx.com said:You say he's obsured to argue about 120rpms
Bah. I'm with Joe, 4.88's all the way5spd GT said:Oh and just so you know there is more than 120rpm real world difference between 373's and 410's...and yes longterm it makes a difference...plus technically you usually shift more (around town driving) with a steeper gear so "technically" the clutch/trans become more worn over time to...
Rootus said:obsured?
Sorry. Couldn't resist. I'm guessing you meant absurd. Sometimes I see things on the forums that just crack me up. Don't take it personally, I'm not taunting you [much].
Dave
Glad I could crack you up. Humor is really the best medicine.
Hell I don't know.... guess I'm just dumb.
But you get my point and communication was made right? 5spd GT said:"Exactly"...
The problem with some of your posts snoozer is that you never really can give a good reason for what you "suggest"...kind of like your traction vs. power post...![]()
95snoozer said:ok, lets try this one more time.....since i have already explained this but you DID fail to comprehend it.
the final drive ratio between the t5 and the 03+ 3650 is different, the 03+ trannies have a .62 5th gear. I was not comparing 3.73s to 4.10s ever.
I said at 70 on my tires:
T5 with 3.73 - 2320 rpm
3650 with 4.30 - 3440 rpm (a t5 with 3.90s is 2430)
t5 with 4.10s is 2550
the point is that a 4.30 in a mach on the highway is barely different from your choice of the mild 3.73s in your rear.
your right, i dont give a good reason, go back and read my ****ing posts. You stay in a high average power the powerband needs at least these gears, experienced racers show what they can do, hell normal people who have balls show what they can do. even that girl from here has bigger metephorical balls than you do.
your argument is that they are too much and not streetable, well i showed thats not true because you assumed incorrectly about the final drive and you obviously dont understand anything about tractive effort and how a steeper gear allows you to stay out of the throttle moving around town. Depending on your driving style you can increase your gasmileage in stop and go traffic. Also with this final gear ratio your highway gas milage is not going to be poor at all. my close friiend could get over 300 a tank and did this several times. his speedo was correct as he was using speedcal.
oh an about your traction comments, i informed my friends with stock new GTs and 03 cobras of your comments and they laughed in my face and thought it was a joke. I see no reason to prove anything to you because you are so close minded you never seem to read anything completely and respond with whatever ignorance you posessed when you came into the thread. You refuse to learn anything new and you wont think outside the box.
Joes95GT said:I wouldn't say that the steeper gears are harder on the clutch either. Shifting normally doesn't wear the clutch nearly as much as taking off from a stop. With a 3.73 gear, you will have to burn the clutch up (ride it out) a bit longer than with a 4.30, therefore the clutch life is probably prolonged.
Also, you could be right about there being more than a 120 RPM difference between the two sets of gears, however, it's not much more or much less than a 120 RPM. It's mathematics and nothing else.
Joe
And you will always be correct
