Dry kit install questions.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Hello everyone just wanted to go over a few questions I have about the Zex dry kit install. Now with the components found in my sig I will be considering running a 75 shot and have some concearns. First is the 190 pump..though it does fulfill my needs currently with the 24pound injectors, will I need to upgrade to the 255?? Second is can the plastic inlet tube be used as a secure location for the nitrous injector? or should I look for an anderson style aluminum intake piping? Last question is regarding the kit itself...will the Zex kit hold it's resale value more or less than other kits available? I am only looking to run this set up for a year, come next fall I lam going to be pulling the current engine for a little more displacement and trade the nitrous for boost, so I want to select components that will get me a good return on my investment.
The 190 pump should be ok BUT a 255 high pressure is ideal. You can buy a fitting for the rubber tube thats kind of like a nut and bolt essentially. Basically uou "nut and bolt" the fitting in the tube and then screw the nitrous nozzle in it so its more secure. The zex kit shouldn't be hard to sell.
