  • SN95 4.6L Mustang Tech
dual focus pumps question
  • Thread starter Thread starter orangemachine
  • Start date Start date Jun 30, 2007
1 of 2 Next Last
O
orangemachine
62
pa
Jun 30, 2007
  • Jun 30, 2007
i have done some searches on here and people say that a single focus fuel pump is good to up to 430-450 rwhp. i just found out that i have dual focus pumps in mine. so, can these pumps handle around 500-530 rwhp?
can i add a bap?
do i need to upgrade my fpdm?
i appreciate the help.
O
orangemachine
62
pa
Jun 30, 2007
  • Jun 30, 2007
i found out about the bap... need to upgrade the fuse box to hold 40 amp fuse (not going to do this)... but i still need to know if dual focus pumps can hold up to around 500-530 rwhp by themselves.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 30, 2007
  • Jun 30, 2007
they should be fine.
i'm running dual GT supercar pumps. they should take me well past 600 and they are only $140 for the pair!
O
orangemachine
62
pa
Jun 30, 2007
  • Jun 30, 2007
what size injectors do you have? and did you have a fitting problems with getting your dual gt pumps installed?
hotmustang331
2,967
Bastrop,TX
Jun 30, 2007
  • Jun 30, 2007
They should hold well in excess of 500RWHP with 60# injectors. BAP would be recommended before you go for big power...same with saleens setup.
My single GT pump maxes out @ 5200RPMs on my car...a dual GT setup should get you to 600, but im thinking it would be fairly close depending on RPM.
O
orangemachine
62
pa
Jul 1, 2007
  • Jul 1, 2007
i only have 42lb injectors... you think i need to upgrade to get around 500 rwhp?
i really do not want to change out my dual focus pumps or injectors
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 1, 2007
  • Jul 1, 2007
you will most likely need 60# injectors. thats what i'm running on mine.
i sold my 42's for $250 and got the 60's for $320. there is a guy over on the MPH forums looking for some 42's right now.
C
Chris00GT
275
York Springs, PA
Jul 1, 2007
  • Jul 1, 2007
I was able to push out 530rwhp on the stock 03 Cobra twin pump with them maxed out. I upgraded to the twin focus setup and did the wire mod with an upgraded fpdm so I'll have room to grow later down the road.
Another upgrade to consider is the fuel line upgrade if you really want to push the returnless fuel system.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 1, 2007
  • Jul 1, 2007
what is the wire mod??
i know i need a modded FPDM but i have no clue about the wiring
O
orangemachine
62
pa
Jul 1, 2007
#10
  • Jul 1, 2007
  • #10
chris... actually when i'm finished building, i planned on coming out to get the stang tuned by you guys. i'm glad you responded because i was going to call and see if i could support 500rwhp with my dual focus pumps and 42lb injectors. i heard that i needed to upgrade my fpdm module too... did you get a stage 1 or 2?
also.. what wiring mod did you get?
i plan on being done in late july early august
O
orangemachine
62
pa
Jul 1, 2007
#11
  • Jul 1, 2007
  • #11
anyone know the cheapest place to get the stage 1 or 2 fpdm... i saw it for around 270 bucks at d'agostino racing
also.. where is this located in the car?
hotmustang331
2,967
Bastrop,TX
Jul 1, 2007
#12
  • Jul 1, 2007
  • #12
42s would make it to 500 but it would be pushing it IMO...like saleen said, your bettwer off getting 60s just to gie yourself room.
Wiring mod is upgrading the fuel pump power wires from your fuse box to the pump with 14 gauge wire. Its generally so the wires dont over heat when you get two pumps and/or a KB BAP....also helps to transmit more power, so your pump(s) see more voltage. even if your fuel system is stock, JUST a wiring upgrade will extend how much power your pump can support because it will see more juice.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 2, 2007
#13
  • Jul 2, 2007
  • #13
got a write up for this wiring mod?
hotmustang331
2,967
Bastrop,TX
Jul 2, 2007
#14
  • Jul 2, 2007
  • #14
Nope LOL, iv never done it myself. However a quick search on both svtperformance.com and modularfords.com should net one
O
orangemachine
62
pa
Jul 2, 2007
#15
  • Jul 2, 2007
  • #15
if anyone finds a write-up for the wiring upgrade, please post because i would like to do this too... if i find, i'll post
think 8 gauge wire would work?
C
Chris00GT
275
York Springs, PA
Jul 2, 2007
#16
  • Jul 2, 2007
  • #16
I used the one off of modularfords in the reference section. I think I used a 10 gauge wire. You don't need to big, since your tying that wire into a relay and factory wiring.
O
orangemachine
62
pa
Jul 2, 2007
#17
  • Jul 2, 2007
  • #17
found the write up in modularfords, very nice... here is my question... since i have dual focus pumps and i will not be maxing them out at around 490-500 rwhp, especially if i upgrade my fpdm to a stage 2, can i just leave my wiring alone?
or.. does the new fpdm require upgraded wiring?
the98stang
2,408
Clovis, CA
Jul 3, 2007
#18
  • Jul 3, 2007
  • #18
can i add a bap?
ONE Ford GT40 pump can handle 530+WHP. Cheaper and easier than dual cobra pumps, or anything else. Requires little modification to make it fit with the stock fuel housing/tank.
hotmustang331
2,967
Bastrop,TX
Jul 3, 2007
#19
  • Jul 3, 2007
  • #19
^ Thats what I was told also on modular Fords as a guy with a GT(40) pump with 60# injectors and upgraded wiring made 530 with that setup.
however when mine was put on the dyno (stock wiring and 42# injectors) my GT(40) pump went 100% duty cycle @ just 5200RPMs. Although my AF stayed fine until around 6000RPM and was still 11.8 @ 6200.
I SHOULD get a BAP, but just havnt got around to it yet HAHA!
the98stang
2,408
Clovis, CA
Jul 3, 2007
#20
  • Jul 3, 2007
  • #20
Still though, that pump is rediculous compared to the cobra pumps. Imagine, 2 GT40 pumps, and you would have PLENTY of fuel.
1 of 2 Next Last
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
New fuel pump relay
  • Scrapla347
  • Nov 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Scrapla347
J
Fuel pump question
  • jay99914
  • Feb 24, 2025
SN95 4.6L Mustang Tech Mar 5, 2025
89ripper
