Are vacuum leaks relevant with a MAP (speed density) setup since we are not dealing with metered air only manifold pressure.
Shortly before putting the car to bed for the winter last fall I removed the intake to deal with an oil leak between the intake and the block. I don't recall any cold start issues at that time. Now, when I first start the car the engine bogs/stumbles with the slightest throttle when cold. Since I haven't changed any of the operating parameters to the EMS, I was thinking a vacuum leak but with the MAP I'm not sure although there is now a whistle coming from somewhere that wasn't there or as loud last year. I was going to pull fuel (reduce fuel enrichment) for the cold engine start period but this doesn't make a lot of sense since it apparently ran fine before. If I just let it idle for a few minutes it's fine although the whistle is still there. I'll test for a vacuum leak but I still think the problem lies elsewhere. I'm thinking maybe the IAC valve.
