Duraspark box vs HEI module
  • Thread starter Thread starter 92LX5spd
  • Start date Start date Jun 16, 2023
9
92LX5spd
58
Jun 16, 2023
  • Jun 16, 2023
I've read about quite a few folks being happy with HEI modules hooked up to their Duraspark distributors. Seems like a good way to go as long as you use a quality module. Are there any advantages in going with the standard Duraspark box?
R
Rcdgl
5 Year Member
Feb 19, 2018
313
168
63
Jun 16, 2023
  • Jun 16, 2023
Have not tried this but the HEI modules, including the parts store replacements work well in mhy 66 Chevelle.
Reactions: limp
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,488
2,909
173
Florida
Jun 17, 2023
  • Jun 17, 2023
Rcdgl said:
My 66 Chevelle.
Any pictures?
limp
5 Year Member
Oct 4, 2020
5,488
2,909
173
Florida
Jun 17, 2023
  • Jun 17, 2023
Clearance problems with fox body stock Air cleaners...... Other than that loved em in all of my GM cars.....
9
92LX5spd
58
Jun 17, 2023
  • Jun 17, 2023
Yeah same here. I'm going to stick with the Duraspark distributor itself to avoid clearance issues but probably use a remote HEI module as the "brains". I was just curious if the original Duraspark box had any advantages over the HEI module other than keeping the set-up "all Ford".
Admin Dude
Jan 4, 1985
43,270
21,446
234
Box behind Walmart
Jun 17, 2023
  • Jun 17, 2023
The ignition systems on our cars are pretty stout. Healthy enough that they've run countless boosted applications exceeding 500 CHP with zero reservations. Like every other ignition system on the planet, they have their weaknesses and components that are less robust than the rest of the system. Even those components (TFI comes to mind) are not what I'd consider "weak". I think I've changed mine once over a span of 15 years of daily use and another 10 as a garage queen.
I have all the factory components and never changed a PiP sensor (another common issue). When I added boost, I also added a Boost-a-Spark which is nothing more than a voltage regulator that keeps the coil saturated even during an electrical system voltage drop or spike.
For the most part, I consider such conversions to be for the cool factor though I don't understand it myself.
Now, replace the EEC with something more modern and I can begin to see the benefits.
Reactions: slow84lx and Bullitt347
limp
5 Year Member
Oct 4, 2020
5,488
2,909
173
Florida
Jun 17, 2023
  • Jun 17, 2023
I believe the biggest benefit to HEI is everything is with the distributor.. Coil and all.... Just add 12 volts.....
Other than that ??
I remember when Delco came out with the points that had the attached condenser..... Sure made life easier not losing the tiny screw that held the condenser under the cap....... Same idea.....
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
New to Mustangs/Fords
  • Joradan93Foxbody
  • Mar 2, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 2, 2026
Joradan93Foxbody
J
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
from6to8
