It's eating boxes. Been returning a friends ex racer '85 GT into a street car. He bought it as a roller with the mechanicals scattered and the wiring hacked dang near everywhere. To repair the wiring I swiped a duraspark harness out of a ex U haul F350 and spliced it in remembering the old addage 'run is red or it'll soon be dead' for the run and start wires (also followed the '85 schematics to be sure). Using a generic box and distributor with a EEC coil caused the resister wire in the harness to smoke when the car fired up. Ended up removing the resistor wire segment thinking it wasn't needed with the EEC coil and tonight smoked the box after it had been running for about thirty minutes. I'm wondering if I should have found a duraspark coil and used the resister wire setup. I removed everything on my old '83 capri with a custom harness, but had a jacobs box between the duraspark and the coil and it worked fine. Any suggestions are welcome...
Jamie
Jamie
