Dying When Slowing Down...
  • Thread starter Thread starter 5.0forever
  • Start date Start date Jun 12, 2012
5.0forever
California
Jun 12, 2012
  • Jun 12, 2012
I have a rather annoying problem with my 87 mustang. It dies when slowing down. When shifting into neutral from any gear at around from around 2-3k rpm, it dies. II changed to fuel filter with no results. I cleaned my throttle body, IAC, set the tps to .98 v, checked for vacuum leaks. I'm at a total loss here, very frustrated... Any help would be greatly appreciated, or if you've experienced the same problems, what fixed it. Thanks.
Here are the specs on my stang:
Trickflow Track Heat intake manifold
Cold Air Intake
3" Mac Performance Pro Dump Exhaust System
x-pipe
E303 cam
75mm throttle body and spacer
MSD 6AL ignition box
Ford Racing 3.73 Gears
Also, I converted it to mass air with a a9m ecu and a pro-m 75mm maf sensor with a fenderwall intake. This car never had cruise control or a vss.
stangman11
220
New Jersey
Jun 12, 2012
  • Jun 12, 2012
Any recent mods or repairs or were all of those mods done before it started stalling out on you?
5.0forever
California
Jun 12, 2012
  • Jun 12, 2012
The most recent is the mass air conversion. It started doing this after it was converted to mass air.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Jun 12, 2012
  • Jun 12, 2012
You're missing the VSS input that the ECU is looking for. You are probably throwing code 27 or 29. Do you have cruise control? If you do, you need to wire the VSS sensor into the ECU. The sensor on the speedo cable where it bolts to the transmission. If you don't have cruise, you'll need to purchase the VSS speedo cable and wire it into the ECU. I *think* that is the only correct way to do it. Doing that will make the computer raise the idle each time you let off the gas, preventing your stalling issue.
Reactions: ratio411
5.0forever
California
Jun 12, 2012
  • Jun 12, 2012
It doesn't have and never had cruise control. It never had a vehicle speed sensor either. I just set the TPS to 1.5v and advanced the timing a little and it stopped dying when slowing down, but I know that this is just a hack. So you're saying I should buy a speed sensor and the harness and wire it into my ecu? because it has no place to plug in a speed sensor, I just put a new speedo cable in.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jun 12, 2012
  • Jun 12, 2012
I agree with Scott. My car did the same exact thing until I wired in the VSS. Just because your car never had a VSS doesn't mean the new computer isn't looking for a signal from one. You may have to retrofit a VSS to correct your problem.
5.0forever
California
Jun 12, 2012
  • Jun 12, 2012
ok cool im gonna do that today...
RacEoHolic330
4,014
1,698
203
Allentown, PA
Jun 12, 2012
  • Jun 12, 2012
You need one of these guys:
http://www.latemodelrestoration.com/item/LRS-9731B/83-93-Mustang-Speed-Sensor
5.0forever
California
Jun 12, 2012
  • Jun 12, 2012
My parts store will have it along with the speedo cable for it today for $50 for both.
RacEoHolic330
4,014
1,698
203
Allentown, PA
Jun 12, 2012
#10
  • Jun 12, 2012
  • #10
Good stuff. Good luck!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 12, 2012
#11
  • Jun 12, 2012
  • #11
here's some help in wiring up the VSS sensor...
MASS air conversion instructions from http://www.stangnet.com/tech/maf/massairconversion.html
Here's some help with the speedo cable replacement...
Speedometer cable replacement for 87-93 Mustangs
Revised 1-Apr-2012 to clarify steps 11, 12, and 13, cable replacement inside the car.
How the speedometer works:
The indicator pointer has no direct connection to the speedo cable. It uses a drum with magnets on it to couple to the pointer. The drum turns and tries to twist the circular steel disk that is mounted on the pointer spindle. The magnetic force is all that connects the drum to the circular disk. There is very little clearance between the disk and drum, only a few thousands of an inch.
Lubrication warning
Use a graphite based lubricant for the speedo cable. It is available at most auto parts stores in a very small tube. Lubricate only the lower half of the cable. The reason for this is that if you use too much lubricant, it works its way up into the speedo head and gets between the rotating magnet and the disk. This causes the speedo to seize up and wring the indicator needle off the indicator spindle. You may be able to fix things up with non-flammable brake parts cleaner to clean the disk and magnet assembly. Plan on replacing the current cable and housing with a new cable and housing to prevent the excess lubricant from doing it all over again.
Speedometer cable replacement.
Note: All 89-93 cars have a VSS sensor even if they do not have cruse control. The 87-88 only have a VSS sensor if the have cruse control.
Speedo cable housing assembly without cruse control:
The VSS equipped cars have a speedo cable with a different fitting on the transmission end of the cable. It is the fitting on the LH side of the following picture.
Speedo cable housing assembly with cruse control
Preparation: if you are only going to replace the inner part of the speedo cable, get lots of newspaper or a painter’s drop cloth to cover the inside front of the car. About the time you have the dirty, oily speedo cable core all over your lap and the inside of the car, you will thank me for this suggestion.
Replacing only the inner cable: see steps 1- 6, 12, 13, 17-21
Replacing the housing and inner cable as an assembly: see steps 1-11, 13-21
Inside the car:
1.) Remove the shield around the steering column that covers the ignition switch & turn indicator switch.
2.) You now have access to the two screws that hold the lower part of the cluster housing in place. Remove them and place them in a zip bag.
3.) Use a stubby or an offset Philips screwdriver to remove the two screws on the top of the cluster housing. The screws are up close to the windshield, so they can be hard to get at.
4.) The cluster housing will now slide forward: depending on your particular car, you may or may not have to disconnect the wiring for the headlights, hazard lights, or cluster wiring. All of the wiring uses plastic connectors with plastic spring clips on them. To release the connectors, lift the plastic clips and pull straight back.
5.) The speedo cable is secured in the speedo head by a white plastic clip. Depress the clip or squeeze it and pull the cable out of the speedo head. This can be tricky, but it will come out if you have the white clip depressed enough.
Speedo head cable clip
Photos courtesy of Almost Stock
6.) With speedo cable removed from the speedo head, try twisting the cable end with your fingers. If it turns more than 1/4 turn, the cable may either be broken or you have damage at the other end where the cable mates to the VSS sensor or speedo pickup gear in the transmission.
Outside the car, replacing the cable housing assembly.
The following steps are necessary only if you plan on replacing the cable & cable housing assembly.
7.) If you are going to the replace the cable housing, the next step is important. Tie a study string or wire to the VSS sensor end of the cable housing. This string or wire is to be used to fish the cable housing back through the maze of wires that is under the dash. If all you are going to do is replace the inner cable, you can omit this step.
8.) Jack up the car, all 4 tires must be off the ground. Place jackstands under the car for safety.
9.) Locate the VSS sensor on the driver’s side of the transmission tailshaft housing. The speedo cable housing will be secured in the VSS sensor with a hairpin clip Do not remove the clip!!!: The hairpin clip stays in place. If you remove it, the odds are that you will not be able to get the cable to stay in place on re-installation. Pull firmly straight back on the cable housing and it will come out. A considerable amount of effort may be required to get the cable out of the VSS sensor, but it will pull out.
10.) Release the cable housing from the clips that secure it to the car body.
Inside the car:
11.) If all you are going to do is replace the inner cable, you can omit this step.
The housing assembly can then be pulled out and the fish string or wire can be removed from the old cable housing and secured to the new one.
12.) You can omit this step if you are replacing the cable & cable housing assembly.
The inner cable can be removed by pulling it out of the housing assembly. Watch out for the lubricant so that you don’t get it on the car’s interior.
13.) You can omit this step if you are replacing the cable & cable housing assembly.
Lubricate only the lower part of the new cable with speedometer lubricant or graphite. Don’t use too much lubricant, or it will work its way up into the speedo head unit and damage it. Thread the inner cable into the housing, turning it as you go. When you are all the way in with the new cable, it will engage the VSS sensor and stop turning.
14.) Use the fish string or wire to feed the cable housing assembly through the dash wiring and out the cable hole in the firewall.
15.) Secure the cable in the body clips, making sure that the cable isn’t rubbing against the exhaust pipe.
16.) Push the cable housing assembly into the VSS sensor until it snaps in past the hairpin clip. Connect VSS wiring connector back to VSS sensor.
Inside the car:
17.) Push the cable housing back into the speedo head unit. You should be able to feel the white clip click into place.
18.) Reconnect all the wires & connectors on the speedo head unit.
19.) Re-install the cluster unit in the dash & tighten the 4 screws that hold it in place.
20.) Re-install the cover for the ignition switch & turn signal.
21.) If the car is up on jackstands, start the car, place it in gear & watch the speedo to see if it works OK. If you didn’t jack the car up, take a test drive.
5.0forever
California
Jun 12, 2012
#12
  • Jun 12, 2012
  • #12
Thanks for the help guys! Just put in the speed sensor and voila no more dying when slowing down. I had suspected I would need to do that, I just didn't know for sure though because my car doesn't have cruise control. Now I just need to get the cruise control speedo cable....
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
