Dynacorn Or Scott Drake Shock Tower/apron Assembly
drivingforce77
I have to replace both Shock Tower/Apron Assemblies on my 70 Fastback. I am looking for opinions on the fitment and overall quality of both the Dynacorn and Scott Drake products. If you have used either, let me know the pros and cons.
Thanks!
horse sence,
If you have replaced both assemblies at the same time, do you have any tips on alignment. Right now, the plan is to use the measurements from this diagram http://www.boss302.com/frame.jpg. I am also going to mount an export brace to locate the upper portion of the shock towers. For the lower portion, I am going to install the motor mounts and fab a flat piece of metal to imitate the engine block mounting holes. I will also mount the lower crossmember.
