Slow5.0 said:I don't get it, you sayin stock long blosk ,that mean stock heads too, there is no way get that much HP with stock long block N/A
No he got Ported Edelbrock heads and a FTI cam
final5-0 said:Cats will make a sniffer wb show lean.
My wb is mounted in the collector of the lt's and it showed about a full point richer than the sniffer wb the dyno was using.
Not bad numbers for your first shakedown run.
Later
Grady
mo_dingo said:Yep, I second that.
You are running too rich across the board. You want 13.0-13.5 for the entire RPM range. Why would the RPM's matter when it comes to a/f ratio? Each cylinder combustion is stand alone; Meaning that no matter if you are running 10000 rpm's, or 1000, 13-13.5 a/f ratio for each cylinder combustion creates the maximum explosion, which makes the most power.
But great numbers for the first time at the dyno. It definately takes a lot of work to understand how our EEC works and how to tune it properly.
What are the specs on your cam? Your power drops off way to early. The intake is not at fault. Seems to me you need some more duration in that cam.
Scott
jetuomi said:cool good to know so my fuel curve is a lot leaner now around 13.0 -13.2 all across the board..
GTJake said:More like 11.0-11.2. Grady said...
That means the sniffer the dyno was using was showing a leaner A/F than what is actually occuring up before the cats.
Jake
jetuomi said:haha, I meant, I've used my tweecer to lean it out a 5% more across the board..
Man do you have a great time with your car, 110mph, nice combo !!!
Stangfreak95 said:No he got Ported Edelbrock heads and a FTI cam
GTJake said:Ok...I must've missed something. Thanks, too bad I can't race in this cool weather and squeeze some more out before next summer.
Jake
Slow5.0 said:Than he have stock short block (not long block)
By the way nice dyno # jetuomi
jetuomi said:no that's me just typing away and not fully explaining myself, haha.. (I think I have AADD, the Adult ADD)..![]()
what cool weather, in Toronto we're having the hottest days of our summer almost.. didn't race all year now its fall I'm going 2x this week !!![]()
are you feeling effects of the hurricanes??
GTJake said:Hurricanes??? I'm in Minnesota! Well, Michigan right now. I mean in the next few months right before the track closes and it's getting real cool.
Jake
