DYNO Guesses & 1/4 times?- Going April 15th
SiK91LX
78
SF, CA
So yeahhh here it goes same stock combo
NOVI2000 8PSI
Edelbrock RPM Intake
65Throttle Body w/ inch spacer
1.7 Pedestal Mount Rockers
Mac U/D Pullies
BBK Headers
O/R H pipe w/Turn Downs
SMOG DELETE
Electric Fan
24LB Injectors
77MM Cobra MAF
BBK Fuel Pressure Regulator
King Cobra Clutch
Aluminum Driveshaft
3.73 Gears
Hurst Short Shifter
Saleen Springs
What will i dyno @ - Im runnin stock heads + cam
And what will i run @ the tracks @ 2.0 60ft?
Dave
i think around 330-350RWHP, but with a 2.0 60 ft I think high 12's around 112-114. Only reason is because I had a stock HCI 5.0 with ATI procharger 3-core IC seeing 10 lbs or a little more with basically same mods: 1.7 rock, bbk headers, o/r h-pipe, flows, 3.73, alum driv, 36lbs inj, 75mm MAF, MSD 6al, electric fan, hurst shifter, steeda springs, LCA..etc... and I was pulling off 2.0 60fts with 12.8@116mph, also low 13's with 2.2-2.4 60fts, not good traction. So i was running more boost but didn't have a intake and TB like you but it should be close to what I was running I would guess.
Thanks alot!! Hoping for 12s - Guys have been telling me i can hit mid 13s without the charger easy and with the charger it will drop almost a full second..,..
ANyone else? Im hoping for 330 at least ---
In May im getting x303 and AFR185s :spot: hopefully hit 400 horses :flag:
