  • SN95 4.6L Mustang Tech
Dyno Loss
  • Thread starter Thread starter weldonGT
  • Start date Start date Aug 24, 2004
weldonGT
100
Florida
Aug 24, 2004
  • Aug 24, 2004
Sorry if this has been explained before (the searches I tried returned WAY too many results to wade thru), but I have a question about the 15% loss between flywheel HP and RWHP:
So the more power you make at the flywheel, the more power you lose before it gets to the pavement? How is that? The power is going thru the same componets, but at 15% loss, then I'm losing more power after mods than before mods. That would mean that the transfer of power is more efficient at lower power levels?? Or is the 15% power loss just a rule of thumb and you're actually losing much more at higher HP levels?
Hope this makes sense.
Thanks
2K1GtfromSC
705
West Columbia, SC
Aug 24, 2004
  • Aug 24, 2004
15% is 15% no matter if you 200 hp or 800 hp it is still 15%.
15% of 200 is 170 hp -30 hp
15% of 800 is 680hp -120 hp
you loss more hp but the ratio stays the same. If this helps
weldonGT
100
Florida
Aug 24, 2004
  • Aug 24, 2004
Right..That makes sense...I guess I'm just wondering why the loss is greater since the componets that would cause the loss are still the same.
The loss would be caused by the friction in the tranny, rearend, rotational loss, friction, friction, friction....so none of that changes if I bolt on more HP so why would the loss be greater (120hp now instead of 30hp)?
white99gt
4,649
stockbridge,Ga(near atlanta)
Aug 25, 2004
  • Aug 25, 2004
Its the law of averages..
Plus when you start making bigger power you have to factor in for example a blower.It takes power to turn the blower ,blower belt ,etc..Thats why turbo cars make more power on the same setup that a blower was on..Nothing to turn so the car makes more power..
2013 Geee T
805
Oak Park, CA
Aug 25, 2004
  • Aug 25, 2004
Just think of it as any mod you do you will loose 15% of its benefit by the time it hits the wheels.
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
Engine No start issue AGAIN!
  • ucnhtmenow1
  • Sep 1, 2024
SN95 4.6L Mustang Tech Sep 11, 2024
89ripper
