  • SN95 4.6L Mustang Tech
Dyno results with new Vortech
  • Thread starter Thread starter 02Vert
  • Start date Start date Jul 30, 2008
1 of 2 Next Last
02Vert
36
  • Jul 30, 2008
I had my day on the dyno today, and I must say I am not very happy.
My setup:
Vortech V2 SQ S-trim 10psi aftercooled
38# Injectors
217lph Focus SVT pump
5 spd
3:27 rear end
Diablosport predator
Pypes O/R X pipe
SLP Loudmouth 2 cat back
I had a total of 352.9 rwhp
and 372.2 rwtq
Those numbers arent bad but here is the kicker, They wouldnt try anything much to see what exactly they could net, they loaded a tune they already had from another car with similar setup and installed it. The part I really dont like is the A/F ratio. Looking at everyones dyno sheets their A/F seems to be pretty flat across the board, mine is really crazy. I'll explain the best I can, and scan my printout and upload it later. The following is my A/F numbers:
2200 rpm = 14.9 (Start of logging)
2500 rpm = 14.9
3000 rpm = 13.5
3500 rpm = 12.9
4000 rpm = 12.4
4500 rpm = 12.0
5000 rpm = 11.6
5500 rpm = 11.7
6000 rpm = 12.2
On the graph it is just a huge downhill slope. I dont know yet what my timing is or anything, I have to learn how to use this predator and see what everything is set at.
Any comments are welcomed, suggestions, advise or anything please.
R
Roblu98
94
East Fallowfield, PA
Jul 30, 2008
  • Jul 30, 2008
It looks like you are starting to run out of fuel on your top end. Do you know what your fuel pump and injector duty cycle is? What fuel pump are you running?
04DarkShadowGT
474
Fort Wayne, IN
Jul 30, 2008
  • Jul 30, 2008
Your first problem is you are running the wrong fuel pump. A 255lph pump was made for the older 5.0 cars. The 4.6L have a returnless fuel system and you will need to get a focus SVT pump or better yet switch to a 03-04 cobra fuel tank and pumps.
02Vert
36
  • Jul 30, 2008
I have no idea what a fuel pump and injector duty cycle is, is that something I can find out with this Predator? If so tell me how to find it and I'll let you know. My pump is a Focus SVT 255lph.
My point with the A/F is that everyone else's I see on here is flat across the board somewhere around 11.X and mine starts out so damn high
04DarkShadowGT
474
Fort Wayne, IN
Jul 30, 2008
  • Jul 30, 2008
Sorry about the pump confusion, but you should be fine on that end for your power levels.
But you said your tuner wouldnt fiddle with the tune to make the a/f curve better. Well that is your problem, you need to get it properly tuned. Most peoples cars are a custom tune, not just one loaded from a car with similar mods.
MyBloodRunsBlue
127
  • Jul 30, 2008
yea i hope you didn't pay them a lot of money to get dynotuned and then get someone else's tune...that's a rip off...they are supposed to make a "custom" tune for you...they can base it off of someone else's but everything is not going to be the same...that's total crap...
jivepepper
776
Under a Sombrero. in WV.
Jul 30, 2008
  • Jul 30, 2008
Pretty close to normal numbers. What size pulley the 3.3 or the 3.6"? Do you have a powerpipe?
O
ONELOWF
10
  • Jul 31, 2008
I don't think you were treated fairly by the tuner. Letting a blown car leave the shop with the a/f's like that is irresponsible.
Your 14's should be 14. 6 or so, and at 3k it should go open loop and see 12.0 or lower and flat lined.
It looks like the other cars tune was used with no adjustment for your maf.
02Vert
36
  • Jul 31, 2008
I didn't pay much, $200.00 and wont pay another penny with them. I guess I'll try to get into MPH asap and try to get a good tune. MPH is only 130 miles or so from me.
I have 3.33 on it now, and no powerpipe. AFM powerpipe was ordered with kit but was delayed in shipping due to guages being on backorder. Powerpipe will be here Friday.
Yes, he loaded the tune from the other car, and made ABSOLUTELY no changes to it. I dont know what my timing is, fuel curve, or anything for that matter. I do see in my programmer something about open loop and stuff, should I change that to be open above 3k?
I'm not trying to make huge numbers, but I do want to make safe numbers, but remain efficient and make as much power as I can. I just knew my A/F was screwed when I saw that big ass slope goin downhill. Thanks everyone for their input.
SilverBullet00
1,150
Wichita, KS
Jul 31, 2008
#10
  • Jul 31, 2008
  • #10
If you take your car to MPH they will find lots of hidden HP. Your AFR is scarry... I wouldnt drive the car hard if I was you.
02Vert
36
#11
  • Jul 31, 2008
  • #11
I'm not driving it hard just for that reason
I dunno if it makes any difference or not but the dyno guy told me that their dyno reads lower than all others anyways cause of the type that it is. It's a Superflow. Does that have anything to do with it really?
SilverBullet00
1,150
Wichita, KS
Jul 31, 2008
#12
  • Jul 31, 2008
  • #12
It could read low.. you probably should have around 375-380hp.. but the big problem is your tune.
02Vert
36
#13
  • Jul 31, 2008
  • #13
So I just got off the phone with Tim at MPH and based on what he told me is that I was screwed with my tune, They didn't actually tune my car at all. The people used the Diablosport wizard to setup a bull**** tune to get us started off of and that's what is still there. There were no changes made to the tune after it was installed. This is why I hate being so new to this forced induction and tuning. These people ripped me off right in front of my eyes and I didn't know any better. Next, I was told that I could run this Vortech kit with my stock MAF and Tim says I can't. It apparently pegs around 6psi and I am at 10psi now without my AFM Powerpipe. I need to find a 90mm Lightening MAF tonight so I can at least go back to these people and watch them closer and get this fixed tomorrow. I knew I should have been closer to 380-400 RWHP than I am but the dyno guy told me their dyno reads lower than others because of it being a Superflow (and I bought that ).
So here is where I get mad, I now have a Diablosport programmer that I cant do anything with, I am out of $670.00 that I spent on the dyno tune (or lack there of) yesterday. I have to go see Tim at MPH and spend another $705.00 to have something done by someone that I will trust from now on for all my work.
Sorry about the rant, I'm just aggravated
ESVA
Jul 31, 2008
#14
  • Jul 31, 2008
  • #14
Too bad u got ripped off. Tim & MPH are the best in the business, and will treat u right
MyBloodRunsBlue
127
#15
  • Jul 31, 2008
  • #15
in comparison i put down 379/370 w/ xpipe only
02Vert
36
#16
  • Jul 31, 2008
  • #16
Most of my pulls were in the 330 range, I didn't get the 352.9 till i loaded my aftercooler reservoir with a bag of ice.
02Vert
36
#17
  • Jul 31, 2008
  • #17
What kind of MAF do you have?
SilverBullet00
1,150
Wichita, KS
Aug 1, 2008
#18
  • Aug 1, 2008
  • #18
The lightning MAF is the way to go. Tim sells it, you could call him back and ask him to send you one. You will need a different tune for it, though.
02Vert
36
#19
  • Aug 1, 2008
  • #19
Yea I drove across the state today to get one, and tried to install it and retune, and it didnt work cause it doesn't have AIT sensor on it, So I called Tim and he told me that on 02' and up models you have to install an AIT in the discharge tube aft of the aftercooler, and then wire it up to the two outside wires on my MAF harness. By the time I finally found an AIT it was too late to drill, tap, install, and tune so I will shoot for one day next week.
Are there any of these other unwritten secrets I should know about before going any farther?
MyBloodRunsBlue
127
#20
  • Aug 1, 2008
  • #20
yes i have the lightning maf
1 of 2 Next Last
W
347 Header Size and exhaust Diameter
  • Wellzy55
  • Jun 6, 2020
  • 2 3
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 19, 2020
CrisNavarro
C
T
Forced Induction Vortech Pulley Question (Long Read)
  • tinker451
  • Feb 23, 2020
2K
Fox 5.0 Mustang Tech Feb 23, 2020
tinker451
T
Shocked by Dyno Results - 1990 Mark VII with 5.0 HO
  • 88Mark7
  • Mar 12, 2018
  • Other Auto Tech
7K
Other Auto Tech Oct 6, 2018
I Bleed Ford Blue
NEW FOX IMPUT/ADVICE
  • Madness7645
  • Jun 22, 2019
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2020
Madness7645
Unexpected Dyno Results D1 Mach1
  • AirTractor
  • May 9, 2017
2K
1996 - 2004 SN95 Mustang -General/Talk- May 10, 2017
squeak93
