Well got my 393 running, and took it to a dyno for a baseline run. This was with 0 tuning. Stock A9P, 13 base timing, about 40psi fuel. Oh yeah, and for now, stock airbox and rubber tube between MAF and TB.
Max RWHP: 343@5150
RWTQ : 414@2750
Not so happy with the HP, but pleasantly surprised with the TQ for an initial run, and at such a low rpm. I know some of you are able to analyze numbers and know about how much more is left on the table. My A/F ratio at peak HP is 12.9 which I believe to be a bit rich for peak pwr. I am thinking that the stock airbox and tube are really choking it down since my pwr peaks at only 5150. I know, I know, spend so much on a motor, and cheap out on the filter.
Any, what are you guys with similar combos puttin out, all tuned up?
Edelbrock Vic JR 70cc heads
Scat 393 stroker crank
TFS 351 intake
75mm BBK TB
75mm PRO-M MAF
30lb inj
XE282 roller cam
BBK 1-3/4 ceramic longtubes
BBK X-Pipe
1.6 roller rockers
10.5:1 CR
Everything else for added strength or looks.
Max RWHP: 343@5150
RWTQ : 414@2750
Any, what are you guys with similar combos puttin out, all tuned up?Edelbrock Vic JR 70cc heads
TFS 351 intake
75mm BBK TB
75mm PRO-M MAF
30lb inj
XE282 roller cam
BBK X-Pipe
1.6 roller rockers
10.5:1 CR
take a grinding tool and open it to 3" or as close as possible. Ditch that 2.5" x pipe and go 3".
(Recently blew the motor in my Super Duty PSD) If I can reach 425/450 at the tires, I would be happy. There is always boost later
