  • SN95 4.6L Mustang Tech
dyno tune?
  • Thread starter Thread starter krly79
  • Start date Start date Jan 11, 2004
krly79
464
VA Beach & So Illinois
Jan 11, 2004
  • Jan 11, 2004
So with my mods, or lack there of, could I benefit from a dyno tune? I was also wondering about how much they cost and would they adjust my dashpot for me so that my idle comes down quicker?
stangman
2,690
10
69
in a 3 bed, 2 bath
Jan 11, 2004
  • Jan 11, 2004
well, with your current mods, i think that your money would be spent better elsewhere. it certainly couldn't hurt, you would most likely find some hp with it. but it's not a must do yet cost will vary with shops, & how long it takes/ pulls it takes
lopey4.6
20+ Year Stangneter
Jan 4, 2004
309
Westlake,OH
Jan 11, 2004
  • Jan 11, 2004
I would reccomend pulleys as your next mod and longtubes.
krly79
464
Jan 11, 2004
  • Jan 11, 2004
I was planning on adding LT soon and some pullies and possibly T/A, but i'm not sure if I want a T/A or, if they can do it with a tune, a dyno tune.
StangLou
1,264
Holly Springs, NC
Jan 11, 2004
  • Jan 11, 2004
The tune wont be able to adjust your timing. Youll have to buy a T/A or put a chip in and do away with your speedcal. If you went with a chip, a dyno could be worth your money. You would be able to tweek your a/f with the o/r pipe, and get your timing set to its optimum setting.
If you just want to do it, it will vary by time and the amount of pulls it takes to get your tune where you want it.
wms004
2,864
Los Angeles
Jan 11, 2004
  • Jan 11, 2004
I wouldn't get a dyno tune untill you get a new throttle body. Then They could calibrate the stock maf to work better with the bigger t/b and your p/p upper intake.. then turn of ur rear 02's and get your speedometer to exact perfection on the dyno, plus add timing safely (which would add same gains as a timing adjuster, but safely). Then your car would be calibrated for high octane and run smoother than ever.. so I'd say its worth it once you get a t/b.. I'd look for some results from a stock p/p intake with diff t/b's because it seems a couple of the new plenums on the market are working best with 75mm.. especially accufab.
-wade
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
M
93 5.0 Microsquirt with Stage 3 trickflow tuning issues
  • marxpreston11
  • Jun 22, 2026
  • Digital Self-tuning Forum
  • 2 3 4
2K
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
