Thanks for responding guys. See this thread:
http://forums.stangnet.com/showthread.php?p=5552014#post5552014
I've attached my dynosheet to this thread which shows exactly where the engine drops off.
What's been done so far: I've replaced the distributior with an MSD; changed ignition to Crane Hi-6s; coil changed to PS1 (came with the ignition); changed spark plugs to Autolite 3923; changed wires to Motorsport 9mm; had the throttle body plumbing corrected; fuel pressure corrected (pressure WAY too high); cleaned the mass air sensor elements; replaced the FMU- calibrated for 30lbs. (190lph fuel pump); engine timing at 10 degrees.
I took the car out to test and appeared my Mustang still misses or cuts out at around 4500rpm @ WOT. When my Mustang is eased to 4500rpm, there is no problem. I managed to get my hands on another A9L computer and i installed it. Since then, i've tested only once and the engine held steady and did not cut out. I will test again this afternoon to see if the problem is really resolved or not.
Thinking back at the possiblity of the spark blowing out.. The plugs are gapped at .035". If the problem is the plug(s) blowing out, how much shorter must the gap be? When i first had the Vortech installed, i was advised that the plugs should be gapped to around 0.22" for starters.
