It's a 94 Mustang with completely stock short block that has 90k miles. It has.....
AFR 165's
AFM B41 cam
1.6rr's
TFS street heat intake
Vortech S-trim @ 9.3 psi
42lb inj.
75mm acufab tb....fox body conversion
Cometic gaskets .065 thickness
high volume oil and water pump
Tremec TKO600
Spec stage lll clutch
full MSD ignition
AEM standalone with 3.5 bar map
AEM wideband and Innovate wideband...1 in each bank
Mac equal length shorty headers ceramic coated
Mac 2 1/2" prochamber w/2 1/2" exhaust
255 pump with upgraded lines and Aeromotive fpr
I guess those are the basics....just ask whatever i didn't put down. It's got about every bolt-on mod.
Anyway the results are 552rwhp and 529rwtq. I'm attaching the dyno sheet to see for yourselves. I went in thinking i would be happy with 450rwhp but really wanted 550rwhp. The 1st pass off the street with no cooldown what so ever was 506rwhp. I then tweaked the maps a little and did the 552. I tried to add some timing but dropped 2rwhp so i took it back out and i was finished. I could've got another 10+rwhp if i let it cool down in between runs but i wanted it to reflect the street.
I took my smaller pulley off for the dyno just to be sure it was dialed before pushing it. With it on i usually see about 13psi so i'm thinking that should put me in the 600-615rwhp range. Next time i'm going to let it cool down completely and ice the intake. So we'll see.....
dyno sheet....
AFR 165's
AFM B41 cam
1.6rr's
42lb inj.
Tremec TKO600
full MSD ignition
dyno sheet....
