When driving my 88 LX around the e-brake light will come on and go off, It helps somtimes to pull the e-brake up slightly and the light will go off. What can I do about this? Thanks
mine did the same thing driving down the road, it would randomly go off and on, if i fiddled wth the handle i could get it to go off temporarily. I had to pull the console off and there was a bad connection that holds the sensor for the ebrake. I tightened a screw two turns and no more problems. Pulling the console is alot of work to fix something small like a light but the light starts to get to you after a while.
